It’s due to the whole photobucket fiasco.
If you are using Firefox browser, just install the “Photobucket Hotlink Fix” add-on and you will be able to see the images.
https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/
Awesome. Thanks Pete7874
So I’m testing thermal stepdown. I may have found the problem. At the 1 min 30 sec mark the light stepped down. 29.2º to 34.6º C (∆ 1.4º) with a slight drain of 0.1 volts.
So I must have screwed up the thermal configuration in Narsil settings. I hadn’t noticed the stepdown when testing outside against the building some 20 meters (≈ 30 yds). I’m sure I had it configured correctly as the program confirmed with 2 blinks. Would have the tailcap quarter turned for some extended period (say a week) reset to a default 90 sec timer? Or maybe I entered 1 click too early when disabling the blinky mode?
This stepdown would be the most probable cause of my primary query “I suspect my Q8 doesn’t output all 5000 lumens”
ImA4Wheelr:
I’ve built shunts for my power supplies. Using Simpson’s Moving Magnet. Don’t recall their F.S. (Full Scale) Voltage but quite low. However, I was passing some 20 volts across the shunt as a threshold to calibrate the meter. Wonder if such could give reliable results at say 3 volts?
At the lower end the shunt behaves erratically as any and all small discrepancy in contact resistance skews the readings.
DO THIS.
Read Me on how to set up:
https://github.com/zakwilson/ceilingbounce/blob/master/README.md
Main site:
Top off batteries and calibrate it with your 1200lm light (especially if it’s a constant current driver).
Costs you nothing and now you have a setup that (in my experience) is surprisingly close to much more expensive measuring equipment.
And as I explored the low level, I exasperated the results with a multimeter current test. Boy did I skew off the handle.
Was quite convinced something folly.
Thank you all, and for your patience.
contactor
Your link to a ‘work in progress’ will be tried out. Great opportunity to try something from GitHub.
Thanks!
Use the Narsil cheat-sheet, and perform a factory reset of your light. It sounds like you’ve messed it up. The default settings are a 3-minute timed step-down for thermal protection. Measure your brightness within 3 minutes.
I wish I knew the answer to your question. If you trust your 5 amp power supply's meter, I would think that you could use it to calibrate an external shunt to a reasonable degree of accuracy. Obviously, it would be better to calibrate the shunt at a current and voltage closer to what you want to measure, but we all have to make due with what we have.
To get consistent readings, I like to use bare wire (no insulation with a fan blowing air across the shunt to keep it as close to room temperature as possible.
