Actually with some CSP LEDs it is not easy to cool the phosphor. Clemence has shown that submersing the LED in liquid allowed driving it much harder.
As to active cooling: lots of complexity, big cost, noise, problematic waterproofing….not my style.
However a big passive radiator shell like Olight X6 Marouder with liquid metal and magnetic pumps would be:
also very complex and expensive
silent
waterproof
And unless it springs a leak it should be very reliable.
Though heat pipes would be even more reliable, much cheaper and should work well enough.
I feel it would be hard to sufficiently supersede the Q8 at a reasonable price point when looking at the current competition. The HaikeLite MT09R with XHP70.2’s is a good step up at $120 with coupon code and then there’s the AceBeam X45 for$135 with coupon code (and excluding the value of batteries included). The X45 is great value considering it has a boost driver that maintains constant output and it can sustain 5,000 lumens without overheating and it even happily sustains it’s 9,000lm turbo mode in winter. A successor to the Q8 would really need to be something special for me to justify buying. Even if it was $80-100, I would still rather pay the extra for something like the X45 to have a well regulated boost driver for more constant output.
While 4x21700 parallel is tempting (40% more power) I think the light shouldn’t get any thicker. Not even the 7mm required to fit bigger cells. I happen to think people with smaller hands already find the light to bulky.
Just wondering, can the Q8 driver handle 6.5 volts?
If so a new longer tube would allow for doubling capacity, without any redesign.
I don’t know the drawbacks of such a driver but I can see it as selling point if all BLF designs allow (at least) 2 cells in series.
If I recall correctly, The Miller wrote about followup lights once the Q8 project was complete… a whole series of lights based on the Q8 design, but scaled up or down to accommodate different battery sizes.
What about a scaled up version with 4 x 26650 and also 4 correspondingly larger reflectors (think Palight Boss 1 size)?
For the throw already done Sofirn Q8 4*XPL HI.
Big cooling fins do not give a significant effect. The efficiency of the emitter is crucial. You can verify this: Turn on Sofirn SP33 (XHP50.2) and Sofrn(BLF) Q8 into 1000Lm mode. You will see that the massive body and big cooling fins Sofirn Q8 has no advantage.
Increase area that’s exposed to the air. That’s what fins do.
Remove the heated air from the fins.
It’s my guess that with a slight breeze the fins will show their advantage.
Without a breeze another thing comes into play. Heat difference cause airflow. While the cooling area of fins is bigger the temp difference to the surrounding air is less. So the airflow is less too.
All that said I 100% agree efficiency is very very important. I think it’s often overlooked.
More efficiency means:
- Longer runtimes.
- Longer turbo.
Less bulky => The body doesn’t need to be heavy to dispensate heat.
I keep going back to the BLF Sabre design because that is exactly what it was designed to do. Separate the head and cool it from underneath.
Instead of re-inventing the wheel, I simply stole the cooling design of CPUs, which is pretty much a “mature” method of cooling and applied it to flashlights.
Fans are dirt cheap and take very little draw. Even passively, the extra cooling right behind the LEDs helps a lot.
I like Acebeam X45 too, but will buy if it use XHP50.2 instead of XHP70. More lumen are good, but not without enough throw.
What about if we increase reflector and put 6 x XP-L HI leds?
