I would like to buy a zketech EBD or EBC but the taobao page is all chinese, aliexpress price is sky high (higher than a hobby charger).
And anyway marking on zketech product are all chinese so it’s not very user friendly.
But a discharger that can be connected on USB is exactly what I am searching for, no a hobby charger that have precise balance charging as I do not balance batttery pack.
Thanks - I have also been using the 3.6 volt Li-ion mode, but have noticed that the final voltage is only about 4.10 volts, so I was thinking that the LiPo mode would get it closer to 4.20. Advisable? Maybe even dangerous?
The result for the first Keeppower 3400mah is in. I only for 3090 mAh out of it using my accucel 6. Discharged it down to 2.8V @ 1A using the Nimh discharge function.
What a disappointment… That is a good 310 mAh less than advertised. Should I open to check if it is a true panasonic cell ?
Your missing more like 70-120mAh (for 1A down to 2.8v). Test / Review: Keeppower 18650 3400mAh Black. Full capacity is only at lower current & down to 2.5v. Panasonic actually gives a typical capacity of 3350mAh, minimum 3250mAh. NCR-18650B specs
I would check the cell anyway tho. As long as you have shrink wrap.
I am looking for a quality battery tester. I have a Xtar VC4 charger but it wont show me discharge rates. would the
AccuPower-IQ338XL-Battery-Charger-Tester- be a good option? I like the new Xtar Dragon VP4 Plus but a 100 dollars is a bit much right now. Any suggestions would be greatly appreciated. Thanks
