Hi guys, I have finally uploaded some pictures on the Jexree Mini mod, sorry it has taken this long.
Remember to open in a new window if you want to see the full size pictures.
Size in my open hand.
Size in my closed hand
Size compared to a pen.
Size compared to the A6 & a Sanyo GA
Weight on my milligram scale.
I like to formulate my own supplements and a good 0.001g scale is a must have
The Jexree Mini weights 16.688g
Efest IMR10440 9.126g = 25.814g So i guess to call it a 26g light with the cell is fair then
Taken apart, You can see i have worn down the anodizing where the clip is, that was my mistake donāt try to twist around the clip without being very careful and it wont happen. The clip hasnāt scratch the anodizing during normal use since.
Donāt use anything other than an Efest IMR10440 or you will just cheat yourself out of a lot of output and enjoyment
The stock driver stripped & measured to find the negative & positive point & soldered the stock wires. I didnāt upgrade the wires but they are quite annoying to solder because they are covered with pvc so the cover melts really easy.
And if you wanted to get more amp, you can always upgrade the led wires to a thicker gauge & drill through the ādriverā board to up the amp, but i like it like this I get about 15 min of use from a charge & that lasts about a week for just around the house EDC use.
I donāt use the QTC as a way to get modes anymore, it limited max amp to much & i could never get it to work right + they wore out too quickly. But i have found another way that works much better and doesnāt limit max amp at all
But how will have to wait :p, i have recorded some videos & i will make a separate post on how to do it later.
That lens you can see there is the stock one, i tried a couple i mentioned earlier in the thread with AR, but i have since learned i REALLY donāt like any kind of AR to screw with my lovely 3D tint
Maybe it can give a few % more in output but with uglier beam why bother.
Another thing you should keep in mind is when you screw on the top bezel it often catch the o-ring, so i use a small flat screwdriver to press it back carefully as i fit the bezel.
The heavily cut down Noctigon mcpcb, i didnāt have 10mm sinkpads when I did this, but even those have to be slightly cut or filed down to fit. But it is so worth the effort because nothing can break the led with a proper DTP mcpcb heatsinking away the heat in to the aluminium body.
I used some arctic silver but i think some fujick might work better, because it is rather fiddly to get the mcpcb to stay perfectly centered if you donāt cut it right.
Fortunately the plastic led holder presses the mcpcb down in to the shelf. But make sure you have enough heatpaste by pressing it down & check the imprint that there is no air gaps, if it are add more or much better make sure you make the bottom mcpcb as even as possible by filing or sanding down any unevenness
The reflector is slightly damaged after an incident where the light accidentally went for a wash in the washing machine :O, fortunately no water had penetrated in to the tube where the cell is, but the reflector got a little damaged.
But thatās it i wouldnāt call it washing machine safe but at least it didnāt blow up And any normal wetness it encounter i donāt have to worry about because if it can survive a washer ride it will survive anything
How it fits in my pocket.
The Jexree Mini with a XP-L V6 3D, beamshot with a crappy mobil camera
And remember this reflector is slightly damaged so it has probably lost a little lumens in the process.
The BLF A6 3D with a well used but fresh of the charger Samsung 20R at full turbo.
The pictures are from a balcony shining down on grass.
I like the beam of the Jexree Mini more, because for inside use & anything close up in front to me the hotspot is big and not sharp and the spill is smooth and wide.
I love my little Jexree Mini & so far i havenāt found any potential EDC light that has taken its place.
I have recorded some videos also, but really donāt know how to publish those yet, but if & when i figure out how to upload those i will try to post those as well.
