JC1 tint bin is no good for me. I wish it was below the BBL. JD1 and JD4 would be even better since I use my WW lights at very low output mode most of the time where the DUV is much higher (greener/yellow). With JD1 and JD4, lower output modes should be just below the BBL.
BanL, if we order 1 triple emitter, it’s $5.78. Is that for 3 LED’s on the triple board? And I assume the triple board is compatible with carclo 10507 optics?
The optic is similar but all dimensions (optic height, placement of legs, leg thickness, I think even led postion, is a bit different from the Carclo standard.
Banl - much appreciate your efforts in trying to get us the "good" stuff we all want.
I have some SST-20's on the way, in 4000K and 5000K, and a KDLITKER P60 triple drop-in to try. I assume the triple drop-in is using your triple board and matching optics.
I'm hoping the triple drop-ins are mod friendly, no glue?
Has anyone done any comparative measurements of the SST40 N5 LED? I ordered some bare LEDs and measured the output and voltage and it was nearly identical to SST40 N4 BA LEDs I had. I hope/suspect I was just sent N4 LEDs. I ordered some more N5 BC as well as some N4 BD (which both have the lower VH voltage bin). I included a note saying it was important I get the exact bins I ordered.
