The default configuration is 6V or dies in 2S2P configuration, and it is dependant on MCPCB type. Kaidomain sells it on 6V/2S MCPCBs.
The problem with a lot of 12V/4S 5050/7070 MCPCBs found in the chinese market is that they route the current of the upper dies to the lower dies via the thermal pad, which leaves it at half the emitter electrical potential and rules it out as valid for flashlights without MCPCB insulation.
As far as I know only leddna (?) has dual voltage/arrangement 5050/7070 MCPCBs available, SinkPAD is the brand:
It is nice option but Convoy driver is 6V. Also I desire more flood light with OP reflector of M21C. GT-FC40 is nice for thrower.
So KD XHP70.2 emitters are all in 6V confuguration if I undersood from Barkuti post?
These are not new (literally years old bad design) and often problematic quad boards/optics. When you assemble them be very careful about how the optic and PCB fits together. It can work itās just not a drop in solution like you may be used to with the plethora of triple options.
XHP70x configuration depends on the MCPCB; I haven't seen a properly done 12V MCPCB in the chinese market with the exception of the above by LedDNA.
The GT-FC40 or other 4S/12V emitters can be driven with an H2-C driver (now upgraded, more powerful). One good thing I see in the H2-C driver is that it supports 2S battery input, or input from 2 cells in series. With 2S cells I am fairly sure the current output could be risen a good deal further without problems.
Too bad H2-C is 2.2A only.
Iāve been looking for a good driver for this LED and aside from 4S FET ones the only good option that I see is GXB100 - but probably only one was ever made.
The Convoy XHP35 driver was tested to be quite āoverclockableā (see Convoy XHP35 Driver Analysis / Testing / Schematic). This new H2-C is still untested, but stock it works with 2S input which is a plus concerning efficiency and power input capability (double voltage by the current is twice the input power).
Looks with great modding potential, hope they didn't cheaped out on something with it.
How long is too long to wait in the current climate? Iāve been waiting 3 months now. The only info I have from tracking is from 3 months ago āInformation Received ā Item En Route to Postal Facilityā. Iāve received a number of different orders since and fear the worst
