He won’t even have to admit it on this one, it is there in B & W for all to see. He screwed the pooch on this one when he mentioned editing and your post in question…. but such is life.
Usually, if a person is given enough rope they will hang themselves. I have even done it to myself a few times through the years………….
He sure is isn’t he. :+1: … I am in fact impressed.
I would send him a “Most Humble Badge”…. but he would probably wear it. :person_facepalming: … And that would blow that.
But just for posterity sake I did want to quote him referring to himself as “expert”.
I did add the BOLD & underline so it would be easy to spot.
And could someone please explain to me what a “picayune tangential point” is.
It sounds to me like someone using big words, that mean basically nothing; trying to dodge the fact they screwed up in something they said.
But hey, I only made it half way through 2nd grade……… so I might be wrong.
Performed a third test (takes about 20hrs) with same two cells but changed charger slots. Got almost nearly same results switching batteries in the respective slot.
Conclusion; must be the chargers inaccuracy…
Does anyone know if VP4+ Dragon cap test operates using same system?
Can anyone recommend a good charger for home use?
VC4SL I purchased because needed 78mm slot length for protected 21700 & 26650 cells. I don’t remember older Opus chargers accommodating longer lengths.
