Klarus Mi7 Ti - Mods
:laughing:
Very nice mod. I love what you did with the switch.
Can you recommend a source for the Trits? My olive green Mi7 needs some bling.
Thanks,
Bob
Thanks mate, FastTech has some tritium options :+1:
Thanks for the recommendation. They have a huge selection.
When you say “existing groove” you are referring to the four existing that are parallel to the switch correct?
Thanks,
Bob
Yeah that was my original idea, I had ordered two 6mm x 1.5mm vials but they were too wide to sit in the grooves at either side so I decided to dremmel out the actual switch to make one fit.
I also thought one or two of the 6mm x 0.65mm trits could sit in the existing switch groove and be covered by a dome of UV glue but they would probably be better in the slots each side of the switch as it protrudes enough already.
Perfect. That’s what I was thinking and what my measurements said but I just wanted to double check.
Thanks for the quick response.
Bob
No problem mate :+1:
Is the head of your titanium MI7 glued?
Not any more :slight_smile:
Was heat required or just some bicycle inner tube and some leverage required.
It is an awesome EDC light but I think wasn’t in my pocket for 30 seconds before it found it on due to that protruding switch.
Thanks,
Bob
The glue was not that strong, I ran the light hot on a 14500 and twisted the bezel off using a piece of rubber to grip.
The driver is also glued but come out fairly easy on this one.
Did you get any trits yet?
Thanks for the help. I tried with inner tube and a vise/vise grips but it wouldn’t budge.
Not yet. I am debating about what I want to do with them.
Bob
Might need to use a bit more heat & teach it who’s boss :slight_smile:
Hey, I’m trying to recreate the shallow switch, but having a bit of an issue accessing the switch assembly. Any tips on how to access that? Does it unscrew from the mid section? And if so what did you use to unscrew it?
