Emissivity also matters on a silver aluminum light versus a black one. Shiny is tough to measure as the shiny surface bounces back the light. It gets complicated, like most things, the further you check into it.
I seeâŚfor many surfaces GM320 will be OK, but for some - it will be way off.
I could write a calculator to convert values back and forth, but itâs not worth the effortâŚ
So wait, maybe Iâm not getting something. How does the expensive one work? You set emissivity value manually, and then the thermometer gives you a reading? Because then you can indeed do the conversion manually. But it also means youâre the one who determines emissivity value must be altered.
It would be nice if youâre thermometer can read/scan emissivity value of the surface, and then gives you this value along with the temperature, but Iâm starting to think this is not the case.
Thermometer canât tell what is the surface emissivity. User has to estimate it by themselves and tell the thermometer, so it can do the calculations internally. Iâm not sure how does this particular thermometerâs configuration work - f.e. Flukes have High/Medium/Low.
Note: sometimes instead of adjusting thermometer for surface emissivity you can adjust the emissivity itself by f.e. adding a piece of black tape on the measured element. For various reasons it may not be possible thoughâŚ
I looked at both, and found out theyâre both cheapos; Iâve got the GS320 btw. So youâre probably not going to get accurate results anyway. But maybe with the more expensive one with the adjustable emissivity you can perform like a calibration; you adjust it so the readout equals the value that you know is true.
So the emissivity function is a bit of a gimmick I think, but you could nevertheless use it for your convenience. Itâs just a few $ extra anyway.
I tried a calculator that converts between apparent and actual temperatures for various emissivity values:
The results are way off for low-emissivity materials.
Letâs take apparent temperature of 150 °C, thatâs what IR thermometers measure directly.
GM320 will show the real temperature of 157 °C and it will be correct for 95% emissive body.
But if the body is 60% emissive (not very low really), itâs actually 230 °C - way outside of expected error even for a cheap thermometer.
What you said makes sense: according to Banggood site, the fixed value of emissivity is 0.95, and the adjustable value is 0.10-100. This means there is little adjusting to higher values, and there is more adjusting to lower values. There is adjusting on linear scale, from 0 to 1, but emissivity is I suspect just like many natural phenomena something occurring in the logarithmic scale. So this means large deviations, as youâve illustrated, comes from stuff thatâs shiny. But how shiny is shiny? Eventually you need to know emissivity, or look it up. The GM300E has a âbuilt inâ calculator, and thatâs it. If you do a lot measurements it could be useful, but if youâre only doing measurements sporadically you may not need it and perform calculations manually. But then again, like I said, itâs only a few $ extra.
Normally you just look it up.
For example from
https://www.thermoworks.com/emissivity_table
So âshinyâ is 0.03-0.1. I donât think at this end of the range any of the thermometers above will really work, thatâs why I used modest 0.6 in the calculation above.
Yes, all the calculations can be done manually. I just find the extra user friendliness worth the $6.
The table shows that basically most materials that are sort of âroughâ have a value of 0.9~0.95. But polished aluminium has a value of 0.05⌠So this means there are lot of surface finishes of aluminium (and anodisation) that will be in between that will be hard to look up.
Indeed.
So what we could do is to take a bunch of battery tubes, put them in the oven with fixed temperature, letâs say 50C or 100C, then open the lid and measure all battery tube temperature values. This should give us insight how emissivity values can vary.
Indeed. Though it would be good to have a regular OK quality thermometer inside to make sure the oven actually delivers the temperature it shows.
Though why not measure them at room temperature?
Oh that makes sense of course. But perhaps you get more deviation with higher temperature?
Weâre moving about topics far outside of my knowledgeâŚbut quickly seeking I found 2 effects:
Surfaces also reflect some IR light from their surroundings, in this test it would be noise. Maybe measuring mirror would tell us something about the noise floor? Anyway, moving up in temperature would certainly reduce the effect of reflection.
Also I see that radiant power is proportional to the fourth power of temperature, so even modest increase would bring the results further apart. Not sure if it matters though.
BTW I noticed there are 2 different thermometers named GM320:
The latter has adjustable emissivity and is the cheapest thermometer with that feature that Iâve seen, under $9. It is also named AN320 sometimes.
