Is this where the 251lm/w comes from?
There is also a peak at 480mn (blue) that we are not consciously aware of that sets our circadian rhythm that is not reflected in that graph.
Other thoughts about this thread
I would assume CFLs are rated at full output, whatever that comes out to eventually
LED chips from Cree were rated at 25ºC, now many are the more ‘realistic’ 85ºC, but i assume you are correct pyro that finished bulbs are rated at a steady state output.
The 0.85 heat sounds like a rule of thumb, just like assume all energy is converted to heat (great rule to cover any situation the led will face), as output continues to increase at higher currents the rule won’t be applicable anymore (maybe a few years from now)
LEDs will always need heat sinksinking, being IC components they need to be kept from overheating and burning themselves out, but as the efficiency gets better less heatsinking will be required and hopefully eventually, only a little bit of it will be necessary per chip.
CFLs work at about 60-75 lm/w, any led below this is not worth it unless its in a form factor that CFL can’t duplicate (ie GU10)
I wish there was more information and more disclaimers on these two technologies on their packages and manufacturer’s websites.
CFLs burn out way faster when used in an on/off situation, they only have a fixed number of starts which is determined by how they were manufactured. This information is not available for any bulb i have looked into. I often use incandescent in bathrooms and other places where the bulb will be used only a few mins at a time as CFLs will only last a few months. LED replacements would be great if they were not as expensive as they are.
CFLS will last far longer then their rated hours if they are not switched on and off frequently. Any situation that has a light on 24 hours a day will make a CFL last double or more its rated life.
CFLs have a bad reputation because the market was flooded by super cheaply made junk, usually chinese manufactured
Neither CFLs or LEDs should be put in a closed fixture that doesn’t allow heat to escape, LEDs especially should be installed in a manner that allows maximum air flow for cooling, never in a closed fixture, and ideally in a fixture that has air flowing around it in all directions.
CFLs shouldn’t generally be installed outdoors unless in a closed fixture where the temp won’t get too cold
It seems low CRI in LEDS is to improve the lumens/watt, hence if we use XM-L to make bulbs they wouldn’t do well in the marketplace. As efficiency improves I hope to see single LED bulbs that put out over 1000 lumens per fixture under $10 each available at Home Depot.
