I measure what is there. I eliminate resistance, improve thermal path, and do every trick in the book to maximize performance. Then I stick the light in a light box built by guys that know what they’re doing and tested against dozens of known lights for it’s synchronization.
Plucking lumens, as is suggested, has nothing to do with it. LED’s make light. Overdriven or otherwise. 60mph or 100. The light is the same. Your ability to use it may vary. I’ve stuck a few of my lights out the sun roof of our car at 70mph and they far exceed the factory high beams, easily producing light that aids the driver’s vision in determining obstruction. Nothing “thin” about it. Video camera’s are well known for being weak in seeing what we see, as are high end DSLR or any other camera. Even the video shows the LED blowing away the factory high beams and giving much higher definition to the sides of the road and it’s contained “obstacles”. I am a photographer. Light is light. The soup mix analogy is pretty wack. I have successfully photographed at 180mph, and in caves with no tripod. Making use of available light is, like so many other things, an adaptive skill.
Your “pair” of 35 watt HID’s are effectively producing 70 watts of light. How many watts is your S2200 producing? Not a very fair comparison, is it? What you are probably seeing is a higher CRI from the much lower Kelvin temperature of the HID’s. Hence your feeling of a “rich” lighting environment. HID’s are what, 3500 Kelvin? Compared to a 5000K MT-G2? And about 12 watts vs 35 x 2? Give your MT-G2 12-16A and see how it fares…
I put a Cree XHP70 in an Olight M3X Triton and saw it pull 14.49A from the 8.4V power supply (2 Efest 35A 18650’s). The light box showed me 6241 lumens from a single emitter (4 die, single emitter) Showing this crazy light to my folks, they were blown away at how a 400 sq. foot room was illuminated with that single light source. Mount that on an ample heat sink and cool it with 60mph winds and you’ll be able to run it as long as you wish. My cop neighbor freaks out regularly on the lights I show him, outside at night in a country setting with distances up to a mile easily obtained. Perhaps the lumens I’m plucking are real. Let me show you… look right here
Images taken with Canon G1X, on a tripod, at 1/2 second exposure ISO1600 f/5.6 in manual focus, manual settings. 2 second timer. Always the same. I’ve been using this setting for a while now, shooting all the lights I build and many are very used to seeing that 55gal red oil drum at 97 yds away. Illuminating an area the size of a football field is quite a lot of proof, I would think.
But then again, perhaps your eyes are getting too tired to drive 60mph. Even I can’t “pluck” enough lumens to help you with that.
Nothing personal, perceived or implied. It is what it is, and we all call it like we see it.
