And all the technical stuff, the stuff that makes them a ‘very good charger’…
I highly recommend reading a HKJ review, and see what he tests for, and make sure he will like your chargers specs and characteristics. Then when someone says can you recommend me a good charger, yours will be on everyones lips. If price is also low, then you would have a winner I would think.
Thanks HKJ.
I meaning is that if some people forget to select the correct battery type, the battey will be damaged, and any other unsafe situation.
So I want to design protection switch for each bay. If the user touch the switch and choose the right types of battery, the charger will go to work, otherwise it will refused to work .
BLF members, Do you think the protection switch is necessary, or not, or have any other better ideas?
Maybe sensing the temperature is the easiest way to tell if the user has made a mistake. To satisfy us, any safety limiting mechanism has to have an override, like military equipment.
I suppose it should either not start without voltage and current settings, use the previous settings or default to the lowest.
• Optional charging voltage (1.5V Ni-Mh, 3.6V LiFePO4, 4.2V Li-ion, 4.3V Li-ion, 4.35V Li-ion)
• Optional charging current (0.1A – 0.25A – 0.5A – 1A )
• Capable of charging different chemistries at different currents at the same time
• Have 3 kinds of operation modes, easy to use
• Each of the bays monitors displays and charges independently
• 8x bays wide enough to fit 8x 26650s at the same time
• Longer bay slots to handle 18mm – 72mm lengths
• Accurate voltage cut off and termination current
• Made from durable ABS (fire retardant / flame resistant)
• Advanced protection features: reverse polarity protection, over-charge protection, over-current protection
• With LCD and LED display charging parameters and progress
• Certified by ROHS, CE, FCC
The techy being inside of me couldn't care less about looks if the guts of the stuff can't deliver. For me, there's no good reason for not being able to precisely tune both current and termination voltage precisely. Sorry but, for the hefty amount of bucks that may cost I'd get some quality CC/CV modules, PSU, battery bays, voltmeters, current meters, etc. and custom build myself a proper charger. That's the way it is with me.
Features
• Optional charging current (0.1A - 0.25A - 0.5A - 1A )
• General mode (automatic mode) only for 1.5V Ni-Mh and 4.2V Li-ion batteries, it can automatic start charging and termination.
• Professional mode (manual mode) for 1.5V Ni-Mh, 3.6V LiFePO4, 4.2V/4.3V/4.35V Li-ion batteries, Have 3 kinds short-cut operations.
• 4x bays wide enough to fit 4x 26650s at the same time
• Longer bay slots to handle 18mm - 72mm lengths
I like the specs but is there still any way to add a 1.5A or 2A charge rate? Most high current cells can safely charge at 2A, and I already have too many 1A chargers.
Edit: I see that you’re already past development stage, so I guess no
Yes, Gyrfalcon All-44 has released.
But we already have a plan to add 1.5A and 2A charging current in a follow-on new model.
Thanks for your kindly suggestion.
