Used my AccuPower IQ-328 for the first time today to "Test" 3 batteries, 2 Sanyo 2700mAh and 1 Energizer 2300 (green top made in Japan).
Quick overview:
1) Independent charging channels, but selections for charge rate or mode (Test, refresh, charge, discharge) take affect on all channels.
2) Selectable charging rates: 200, 500, 700, 1000, & 1800mA. 1800mA only available while charging 2 cells in channels 1&4. After inserting battery(ies) you have 4 seconds to select the charge rate (defaults to 200mA, after 4 seconds it locks the charge rate and you can't change it without removing the battery and re-inserting).
3) A/C adapter is rated 3V 4A.
4) According to the specs, the charger automatically switches over to a "trickle charge" and has overheating protection.
5) The "Display" button toggles through status displays of voltage, time (which resets to 0 with change from charge to discharge & vice versa), current (mA), and charged capacity (mAh or Ah - mine only showed Ah with 2 decimal places during my AA test). The current display seems to be the real "true" current and not just the "500" or "1000" etc. . . (ie. you'll see 998mA or 1001mA)
6) "Test" mode always discharges at half of the charge current with a max of 500mA discharge rate for a 1000mA charge rate.
7) "Test" mode first fully charges, then discharges, then displays the mAh capacity while recharging.
8) The 3 cells I tested never got hot nor did the charger (just slightly warm).
Results for my 3 cells tested:
Cell Tested Capacity Ending Voltage
1. Sanyo 2700mAh - 2,440 mAh down to ___v (didn't see ending voltage)
2. Sanyo 2700mAh - 2,510 mAh down to +/- 0.95v voltage (this was the last voltage seen just moments before it kicked into charge mode)
3. Energizer 2300mAh - 2,270 mAh down to +/- 0.91v (this was the last voltage seen just moments before it kicked into charge mode)
I believe the charger charged all the cells up to about 1.45v (by charger display between the charge & then discharge modes) - they are still recharging now, so I am not at the end of the cycle to verify fully charger voltage. (Will try and update on this.)
Some photos:
Channels 1&2 charging while channel 4 is discharging:
Elapsed Time during discharging:
Showing Voltage Status:
Resulting Tested Capacities:
Recharging charge currents:
These cells have been through just a few discharge/charge cycles on "dumb" timer-based chargers. The two Sanyo's look ugly on the bottom because they had briefly been used in a homemade battery pack.
Hope this information is useful. I like this charger, but it is only my first "smart" charger. Someone (or many) once said that adding the ability to test batteries only adds to the joy of collecting flashlights and I have to agree with them. I'm not sure why I didn't get one of these sooner! I'm really curious to now test my cheap Harbor Freight 2000mAh cells! I will report back on those as I know others have them too.
-Garry
