Ordered via PM, I wish those custom retaining rings were standard issue, hehe, no more messy soldering over fine threads
Actual situation:
1.5mm thick brass tail board - in progress (will be ready in a week)
stainless steel hex tail screws - on the slowboat from China
hex wrenches - on the fastboat from the US
Golden plated springs - on the slowboat from China
I still not sure that using brass board without isolating most surfaces is safety decision. But applying solder mask to each would take so much time that Ill probably never finish it.
Plactic inserts inside stock positive driver ring (mechanical reverse protection) - still dont have enough information about different button tops: Low-cost copper pills, spacers, optics, drop-ins (Updated 23/10/2022)) - #1064 by kiriba-ru
12x led kit wont be available, have another idea but it will probably goes to the new “tax choise” method described in the end of this post:
Did you ever reveal what this was?
No. Id like to finish this samples before.
I’m sticking with tire-valve caps.
I just had a crazy Idea. kiriba-ru I wonder if you could make Lightsaber hosts! Could find a niche on some Star Wars fans.
I even had “lightsaber” mensioned in topic name some time ago. But havent received any ideas or wishes.
Well You seem pretty savvy with machining, and you do such a great job. So I have no doubt you can do it!
Surely you mean lighted tire valve caps?
I will ask those who are interested in VG-10 quad to open your hosts and specify which version do you have:
Old version from one of chinese websites. Head internal surfaces are complete anodized (no shiny machined surfaces), o-ring between reflector and stock glass lens. Bezel is flat from bottom.2)
Medium version from amazon deals. Head is machined inside, o-ring around glass lens (between bezel and reflector). Bezel have rim so glass enters inside bezel.3)
Epic fail version from thorfire GB. Extra aluminium disc and LB pcb under main pcb.
Still make these?
Still have several various vg10 kits.
subbed
Q8 boards for 2s/2p , 4s batteries order etc ?
Right.
I cant see this driver backsides with 4 independent cell contacts. I immediatly imagine big badaboom. Also, I cant understand how do Lexel and others plan to fix tube in right position - which is necessary with 2 screw holes in driver (ie you cant rotate driver to proper position to align cells).
I didnt found any simple ways to make 2s/4s mod safety. Im going to:
- reverse battery tube.
- use stock tail pcb place (now it is faced to the driver) for medium board (#1 for 4s or #2 for 2s), so you could turn tube in head without any short-circuit risk
- make custom tail. With deeper threads (stock tail wont allow to screw all down to the head side tube threads) and with place for custom tail board (#3)
- make custom tail insert that have “pins” which could fix between cells and rotate (together with tail board) inside custom tail
What if the personal wanting to know the measurement does not have a 30Q BT at hand?
The difference on mine is 1.5 mm
Just measure both sizes with the caliper, then subtract one from the other and you got your button size
I suppose I listed enough information why did I had to ask this question.
I had lots of button top cells, and many lights with mechanical reverse protection. Not any combination could work.
Kiriba, do the copper pills for triple convoy S2+ come with a retaining ring?
Yes - I suppose it is mensioned clearly, no?
