Lumintop FW1A discussion and review
I just got a response from Neal, and he said there will be a FW1T. He also mentioned a SS FW3A without knurling. That sounds interesting.
:smiley:
Is someone playing a game of how fried they can get their LEDs?
Steel can be pretty nice, as long as weight isn’t importand and the LEDs inside aren’t turned up too high.
In a FW3A, I’m guessing a steel version would probably regulate down to the regulation floor, and then mostly just stay there. Steel is good at keeping the heat in, so the highest sustainable level is probably just a couple hundred lumens.
I have FW3A, FW3C, FW3T and FW1A
I wish they were FW1A, FW1C, FW1T and FW3A
I really like the FW1A, I guess I’m tired of TIR + multi led flashlights
Very cool flashlight!
But in my FW1A there was no gasket under the glass :frowning:
maba, I said it on FB, but I’ll say it here, too. Thanks for the pics! Looking forward to this one. I’d really like to see how it compares to the SC64 and S2+.
Gasket?
It should have these parts, stacked in this order:
  • Bezel
  • O-ring
  • Lens
  • Reflector
  • Centering ring
  • MCPCB with LED
There is no gasket.
From the pics you posted, your FW1A appears to have the correct parts.
What a great collection!
This leads me to want the FW1A :weary: :stuck_out_tongue:
Funny, I was going to say it leads me to want a D1 and two Zebralights.
Before that picture, I thought the Unicorn was shorter and narrower. I assumed it was the size of a SC64.
Maybe he means the o-ring between the bezel and lens?
Gasket = o-ring
Yes
Because I took from the backup FW3A, otherwise there was a rattle :smiley:
These orings are a bit too small and too thick: https://www.fasttech.com/p/1088607
Hi all,
I’ve been introduced here by stephenk from a post on Light Painting Blog.
As a lightpainter, from what I’ve read, I think FW1A is one of the best flashlight to have in our arsenal. Especially because of Andúril and its new momentary strobe feature.
Could someone tell me if the FW1A has the new July update of Andúril firmware?
I read FW3A/1A drivers aren’t updated yet by Lumintop…
Thanks
ToyKeeper probably knows, is there any way I can check? I know this version has the two stage lockout, but no factory reset.
I’ve only tried one FW1A, but it has momentary strobes. I think almost all FW3A / FW1A lights are shipping with a version new enough to include that now.
Checking is relatively simple… go to a strobe mode (“click, click, hold” from off), then turn the light off, then go to momentary mode (5 clicks from off) and press the button.
Getting out of momentary mode is a bit inconvenient on FW3A/FW1A though, since it requires disconnecting power. And on this light, that means unscrewing the battery tube pretty far. It’s much easier to exit momentary mode on other lights, like the Emisar D4.
The button placement may also be a consideration when choosing a light. Side switch or tail switch may be more convenient, depending on what you’re doing.
Just received this light today and I absolutely love it. Great beam profile with the SST 20. One advantage of throwy reflector lights I’ve noticed is in tail standing to create diffuse light in a room. The candle mode in anduril is much more effective this way than with optics. Perfect for late night reading.
Welcome to BLF , Frazil .
Ok. So there’s no manual momentary mode yet (your July update), but there is momentary stobes. I can easely live with that. Thanks for your help and your reply!
About the button placement: yup you’re absolutely right. That’s why I rather choose tail switch button flashlight. Because we often attach some sort of light diffuser (e.g. plexiglass) onto the head causing side switch difficult to reach.
Thanks for your quick reply bmengineer. Useful tip.
Thanks a lot :wink:
