Features:
-Integrated Precision Digital Optics Technology provides extreme reflector performance
-Single button access to 5 brightness levels and 3 special modes
-High efficiency constant current circuit board for lengthened runtimes
-Low battery power indicator light
-Flood lighting system provides a wide, 100 degree angle
-Advanced temperature (ATR) technology
-Comfortable headband constructed from quality elastic nylon
-Reverse polarity protection prevents damage from incorrectly inserted batteries
-Toughened ultra-clear mineral glass with anti-reflective coating
-Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish
-Magnetic base and tail stand capability
Package included:
1 x Nitecore HC33 XHP35 HD 1800Lumens L-Shaped LED Headlamp
1 x Headstrap
1 x Pocket Clip
1 x Spare O-ring(s)
1 x Spare Tailcap Boot
Features:
· Astrolux C8 is redesigned with BLF A6 driver which is more durable, more powerful, and more functional.
· Utilizes a XP-L HI LED
· High efficiency constant current circuit enables maximum output up to 1300 lumens
· Driven by one 18650 battery for maximum runtime up to 300 hours
· Boasts a peak beam intensity of 102000cd and a throw distance of up to 639 meters
· Hidden battery check
· Direct access to ultra-low and turbo output
· User selectable "4 or 7 evenly-spaced modes".(Moon to High)
· User selectable mode memory (always starts on Moon without mode memory but easily reverses to Turbo with a click)
· Fast PWM for lower regulated modes
· Toughened ultra-clear mineral glass with anti-reflective coating
· Constructed from aerospace grade aluminum alloy
· HAIII military grade hard-anodized
· Waterproof in accordance with IPX-8 (2 meters submersible)
· Impact resistant to 1.5 meters
· Tail stand capability
Package included:
1 x Astrolux C8 XP-L 1300Lumens 7/4modes EDC LED Flashlight
1 x Lanyard
1 x O-ring
I have feedback. I didn’t register because I have a feeling that the amount of information that you ask for is simply excessive. I do have a feeling of missing out, but this goes beyond my limits.
I know the feels, I have a Lumia 640. Great 40$ capable smart phone if not a big app user, surprisingly decent cam. But some websites just don’t work with the browser it has.
For those people that were interested in the Amutorch JM70 :
Got the light today , build quality seems to be very good , reflector has a perfect finish and led is on a 25?mm dtp copper mcpcb .
I think output is a little less than advertised , but better wait until i make the measurements for my review . Rear switch is used as a lock out , so for example when you press it from off , you still need to press the side switch to turn the light on (ui is : low - mid - high - strobe , when off : single click enters last used mode , double click enters turbo , when on : single click changes modes , longer click turns off the light (that you can also turn it off from the rear switch))
