Nice review with lots of photos I also bought the youth version and the kids version recently during the 11.11 and BF sales. My main issue is the lack of wall holder for the bluetooth remote, so I am constantly looking for it when I get into the two rooms where they are fitted. Have you come across any wall mounted holder that is suitable for the remote?
There are ring magnets you can screw on the wall or furniture. countersunk ring magnets . Add a metal plate on the remote with double sided tape (or open the remote and add a magnet inside).
You can fix that ring magnet even on the underside of a shelf
Or you glue a strong magnet under a nice pice of wood and fix that on the wall
There are DIY solutions
Google for: magnetic knife holder diy
Features:
● Utilizes XP-L HD LED with a lifespan of 50,000 hours
● Compatible with 18650 or two cold-resistant CR123A batteries
● One switch controls 5 output levels plus Strobe, SOS and Beacon
● Max 950 lumens output and 18.5 days max runtime under Moonlight
● Micro USB rechargeable, with charging and low voltage indicator
● Silicon headlamp holder makes a comfortable wearing
● Detachable reflective and anti-slip sweat-block headband
● Detachable stainless steel clips allows more wearing manners
● Magnetic flat tail cap with tail standing ability
● Multifunction serve as a headlamp, angle light or flashlight
● Made of aerospace-grade aluminum with premium Type III hard-anodized anti-abrasive finish, more durable in use
● Floodlight design creates a smooth and comfortable flood beam
● 5 years free repair, limited lifetime warranty
● Operation:
- General mode: Press the switch for ON, another press to cycle through Low-Med-High-Turbo; long press the switch for 2 seconds for OFF. Next time you turn on the lamp, it will memory and enter the last used output level.
- Moonlight: When the lamp is OFF, press and hold the switch for 1 second to enter Moonlight, another press to enter general mode.
- Flash mode: Under Moonlight, double press the switch to enter Strobe, press to cycle through Strobe -SOS-Beacon.
- Lock-out/Unlock: Under OFF, long press the switch for 5 seconds till flash to lock the lamp. Under lock-out statues, click or long press the switch can momentary light up on Low until release. To unlock the lamp, just loosen the tail cap and cut off the circuit.
Package included:
1x Lumintop HL18 XP-L HD 950Lumens Multifunctional Headlamp LED Flashlight
1x Silicon holder,
1x Headband,
1x User manual,
1x Warranty card,
1x Spare O-ring
1x Clip
Klarus Mini One XP-G3 130Lumens USB LED Keychain Flashlight
Brand:
Klarus
Model:
Mini One
Emitter Type:
XP-G3
Material:
6061-T6 Aerospace Aluminum Alloy
Mode:
High,Low
Lumens:
130LM,8LM
Runtime:
24min,5h12min
Range:
30meters,9meters
Battery Configurations:
1 x 10180 li-ion battery (included)
Working Voltage:
2.7-4.2v
Switch Type:
Twisty
Switch Location:
Head of the light
Peak Beam Intensity:
217cd
Impact Resistant
1.5m
Waterproof:
IP68 waterproof 2meter
Color:
Black,Red,Olive
Weight:
13g with battery
Size:
14.9mm x 13.5mm x 44mm (head x body diameter x length)
Features:
•XP-G3 LED, up to 50,000 hours of service.
•Mode: 2 lighting modes.
•Finger-sized mini-might flashlight, elegant,compact.
•Titanium, light-weight, robust build, corrosion resistant, excellent heat dissipation.
•Li-ion rechargeable battery included;
•Micro-USB charging port, easy to recharge.
•Fast charging, only 45 minutes charging needed, no waiting.
•XP-G3 LED, max output up to 130 lumens.
•Professional optical lens design, even-lit flood light, soft beam.
•Dual mode, easy to use for daily need.
•IPX8 (underwater 2 meters), 1.5 meters drop resistance, multiple applications.
Package included:
1 x Klarus Mini One XP-G3 130Lumens USB LED Keychain Flashlight
1 x Sapre O-rings
1 x Keychain Ring
1 x Mirco USB cable
1 x 10180 battery
Crazy good deals on some lights, makes me sort sorry I bought my Meteor M43 although it is a great light, but it’s considerably more than this MT03 ll and about 5000 lumens less. Could have also gotten that O-Light Marauder something or other for $90 on sale, amazing light with 9K lumens.
