Very interesting test results. Looking forward to more Maybe Toykeeper can chime in on the 7 minute step down.
Thanks for your hard work!
Thanks for your work and testings Zozz. Looking forward to your graphs and Videos.
The fact that you have this first drop, at around 30 sec, in all cases, no matter which output level, sounds to me like you still have an thermal conductivity bottleneck.
From my experiences while testing, this can happen if the contact between copper heatsink plate and the surfaces at the driver pcb and the head inner diameter is thermally bad contacted.
You probably already have done this, but please make sure that thermal compound is putted on all surfaces I marked green in my description, not only at the top surfaces of the AMCâs. This can make the difference to avoid the first step down.
I am looking forward to your results, thanks again.
You are right! I only putted thermal grease on 7135s top. I will disassemble and add to the rest of the surfaces where needed.
i know this could change cost, but whats the issue with using a thermal pad?
that way it can be more precisely cut, applied, and with the precut parts everyone knows where it goes. also you can engineer the copper with an exact spacing to create 0 gap.
Wonder how the alu + copper version result vs stock for mf01 mini, but Iâm about to order thoseâŠ
ZozzV6, youâve got stock right??
Yes I got a stock full aluminum body MF01 mini.
Removed the copper and found the thermal paste barely spreaded out. It seems helped a bit but I think there is much to improve. The gap was too big above the 7135 tops for a grease.
So I tried thermal silicone blocks this time. Cut them to size and the copper thing spreaded them out.
Then I cutted very thin layers to press thm between head side and copper spacer side:
These two graphs with 35 click ramp max setting so 1367 lumens at start. The left was just thermal grease on 7135 tops. The right was the silicone stucked version test same settings. Much smaller drop in beggining and no drop after 9 minutes. Needed to interrupt test because we had a coffee break at work
There is nothing between driver ground edge and copper spacer so maybe there is a tiny bit to improve that first little drop but it is much better.
Further tests coming weekend.
I hope this will be corrected by the time of shipping....^^^^
Corrected what?
The first run was not so good because I didnât followed instructions but better than plastic. Second is almost perfect but I still doesnât put everywher thermal halping material where it needed. So the copper thing is good just need to follow the instructions precisely. It is a bit hard to put thermal compound to the copper side but it is doable.
Ah ok. I thought itâs design. That sounds nice.
Thx for clarifying, wasnât paying attention.
@Zozz, thanks for explanation and the latest results :+1:
The idea to use thermal silicone pad is not bad, nice pics, thanks for the work.
Itâs really important to spread the thermal compound on the defined surfaces, like shown in the description in post #1 and on this pic below.
Before mounting it should look like this, but here is a bit too much thermal compound paste spread on in this pic, just to show where it should be.
After mounting, use a cotton pad to clean up excess residues.
This gap is around 0,1 and 0,2 mm after mounting the copper heatsink plate. It depends on manufacturing tolerances and tolerances of the components (7135) and also of the pcb and soldering process. Designing this gap closer is possible, but it brings some risks. It may be possible that another production batch of driver pcbâs will not fit or there will be no gap. Tolerances differs often on pcbâs.
Therefore the idea to use thermal silicone pad is not bad, but in most cases you will achieve better thermal conductivity with grease/paste.
As you said you canât design it to get too close to 7135 top because if it has a bit more solder under you can possibly break them tightening the copper. You need a bit of clearance. That is why I tried silicone. It works like a gum and reach the 7135 sides too because of the pressure. So more contact surface to get off the heat. I maybe only use paste on that contact ring on driver. I think I will disassemble it a few times to get best results.
Iâve always learned that thermal grease is only to fill in the tiniest of pores and scratches between two metals. You guys are killing me with just glooping it all over and trying to fill in these giant gaps. Lol
Recently, I needed to buy Arctic Thermal Pad and it works quite well in one flashlight. Cutting the right pieces is probably a better solution than dirtying everything around with paste.
Ah too bad I missed this. Would love to improve my 3 mf01 minis!
In for 1-2pc if there is a 2nd batch
I will put you on the list for a possible second batch, will provide it soon in post #2, if there will be enough interests it could be realized.
Iâve always learned that thermal grease is only to fill in the tiniest of pores and scratches between two metals. You guys are killing me with just glooping it all over and trying to fill in these giant gaps. :confounded: Lol
Youâre absolutely right, thermal grease should be used very barely, always use as less as possible of it.
In this case we are taking about close a gap in the range of 0.1 to 0.2 mm as max. Between GND surface and copper plate is nearly no gap.
if there are 2 pieces left, please consider me.
Thanks,
olles!
Thermal pads have worse conductivity than pasteâŠbut their big advantage is that they are solid. Paste may move around and leave you air gaps just where you donât want it.
Thermal pads have worse conductivity than paste.
I think thatâs only true when both are used properly. Since we are not using the paste properly I think we have to throw this whole statement out.
BTW, are these thermal pads like the ones used for cpuâs? One use only, once separated you have to throw it away and use fresh pads. Plus you have to get the pad really hot in order for it to conform to the proper shape. Maybe newer style pads are designed differently?
