my 2nd order came $21 (took a long time) and its even better i am glad to say they are making small improvements that are significant
one thing i notice is the slide mechanism to insert batteries is smoother then the 1st version and is a welcome improvement as compared to the early 1st version the slide is not as smooth
it now comes with a patent # and trademark logo printed on it
Slide mechanism is really smooth, its way better than my VP1.
I bought mine from GearBest and it’s a version with patent number and logo.
Really happy with this charger
Can somebody explain how bad is for NiMh when charging stops early as HKJ reported?
Do we just wear battery faster and loose some capacity? Any other disadvantages?
I do have another charger for NiMh but I wanna carry only Lii-500 when traveling.
So far I’ve charged some old NiMh AA pulls (Sanyo) from Motorola walkie-talkie and it seams fine.
I still haven’t tried to charge my better NiMh though…
I ordered one from GB, but they said theres high demand for it and it will take up to two weeks for it to get back in stock due to manufacturing speeds.
The listing for this charger says :
“overload and over discharge, short circuit, temperature, voltage 0 V role is enabled, (& Delta; 0 & V and Delta; V), 1.65 B 2.2 B can not be charged, intelligent recognition and reversal of bad battery detection protection battery.”
Is the voltage 0 V role is enabled, (& Delta; 0 & V and Delta; V) referring to Lions or is it also for Nimh?
If its fornimh then it means they would’ve upgraded the charger and it would possibly not use voltage detection for nimh right?
Many chargers has both -dv/dt and voltage termination, but if the voltage termination is placed at a low value you will never see the -dv/dt in function.
