[quote=RMM]
Hey RMM, how did the MT-G2 build come out using the ZY-T08? Did you ever get er done?
Curious, would like to try one myself.
[quote=RMM]
nice mod ! i like this formfactor size, especially in your modded version with matching a SRK.
How did you get those two the solder blobs to stick to the aluminum pill?
The MT-G2 came out well with the ZY-T08. I used one of the original DRY drivers, copper braided everything, etc. IIRC it does around 5.5A on turbo w/ Pana PDs and 6.5A w/ 20Rs. I still hate the whine from the driver, it is just too much for me. I tried changing out switches, tightening and cleaning ground, etc. but it is still pretty bad.
I'm going to switch the DRY out for a zener modded 105C with an FET which I now feel is a superior solution. In my testing it will pull over 10A on 20Rs and still gives me good mode selection and very minimal whine. DBCStm put one in his MT-G2 M8 and had it putting out over 4000 lumens on 20Rs and measured a 7 lumen moonlight. Doesn't get any better than that! If you want to turn it down a bit just run a lower mode or run weaker cells.
