Ah yeah, I see what you mean now. With 3 voltage indicator lights there is no room without using the Reset pin.
Pins:
- N/C - Reset
- GND
- PWM
- Voltage ADC
- Vcc
Pins:
Come to think of it, there’s already no room! You need a pin for button input as well as the 3 outputs for status LEDs.
Is there anyway to leave the stock MCU in place to drive the indicator LED's (& thermal protection if it's in there too) and just use the Attiny to control the light output to the XM-L2's?
-Garry
I think some of that should work:
Low voltage warnings through the ATtiny could be disabled, so that only Low Voltage Protection / shutdown would be present. You’d have different microprocessors running the LED status indicators and the actual shutdown. The LED status indicators would remain the same and continue to behave as they did on the stock light, potentially including or not including heat warnings.
In order for the light to shutdown or throttle based on either temperature or battery voltage the ATtiny would also have to be hooked up to those dividers. That should give you just enough inputs to hookup 2 dividers (the temp thermister is likely part of a divider, I think that’s the normal setup) plus the momentary button.
The LVP shutdown may not be as effective with so many devices idling - 2 buck controllers and 2 MCUs. At least the ATtiny13A will go to sleep, but the rest of it may not do as well. I still think that it’s a good idea, I just want to point that out.
I doubt heat will be an issue during a ride, but low battery definitely can be. If you have to choose features to not enable, I’d suggest leaving out thermal monitoring.
Using the stock MCU for the indicator lights is an interesting idea, and eliminates the pin overload.
It definitely sounds like it would be a bad idea to leave the light connected to a low battery though… since several components will always be powered up and we don’t have control over most of them.
This project is kind of fascinating in a bizarre way. I know almost nothing about circuit design, so I keep seeing surprising things here.
^ I agree. Given the power levels Garry has decided upon and with Turbo Timeout, heat should not be a issue in most situations.
How would we keep the stock MCU in an "On" mode?
It only runs lights the indicator LED's when it is powering one of the two headlight LED's (an "On" mode). It would need to be connected to a momentary switch or something in order to turn it "On" in case it goes into "Off" mode. I'm guessing it would go into "Off" mode every time it's disconnected from power.
Good point! There are probably a couple of options. How does the stock driver respond to holding down the button from off? If it simply switches to the first mode and stays there then that’s your answer.
^ Very clever wight. You're saying if it works that way, then just hard wire the stock MCU's momentary switch pin to ground, right?
Ledoman,
Can you please try holding down (and not releasing) the power switch from Off mode and tell us what the light does?
EDIT: Ledoman,
Your suspicion was correct, that component is some sort of thermistor. When I aim a hair blow drier at it, voltage output drops quickly. Turn off the blow drier and the voltage starts climbing back up slowly. I just don't know how to get a good read on what temp equals what voltage. I don't believe I have anything that can measure temp of such a small object.
EDIT2: The voltage dropped pretty rapidly and slowed down when it started to approach .3 volts. I would say it seems like .28 would be a good starting point. I could have to run the light assembled to see at what exterior temp the thermal control kicked in and then adjust the settings from there. I guess we need to hear what ledoman says about the power switch being pressed and held. Then it seems to be decision time.
Exactly. The status lights would always be on when batteries are attached. Really that’s OK, as we’ve already established that storing the light with batteries attached would not be the best thing to do.
Regarding calibrating the temperature measurement: you are thinking about the situation in reverse. Based on your comments I assume you have an IR thermometer. It needs a half inch diameter circle or similar to measure, much much larger than the thermister. If the thermister was a 0805 component which generated heat we would be unable to measure it’s temperature: it’s too small. But since we are talking about a 0805 component which responds to heat… which we are testing with a large hair drier… we can safely assume that the entire 0.5in circle around the thermister is also the same temp. So using any old temp gun should be able to get you an accurate reading.
Yes, Garry said he disconnects power when not using the light. Just need to hear back from Ledoman or anyone else that has a HD-016. Reassembling the driver is a last resort to getting that info.
Good point on testing. I'll do that. Thank you. :)
Sorry I was away. Edit: Upon holding down the switch from Off the light does nothing. Also the status leds are not powered up. Only short press puts it into wide beam on and brings up status leds.
Regarding stock MCU you might look just posted circuit drawing about DX driver (http://club.dx.com/forums/forums.dx/threadid.1343534?page=21) - IC4. It might help you resolving it's functionality. It has pretty much different UI, but the pinout should be about the same.
Thank you Ledoman very much for trying that out. Wow, that driver's MCU has so many differences in nin out that they really are not comparable. Like you, I figured they would be similar too. Garry's pin out is as follows:
01 Vcc
02 Indicator LED
03 Momentary Switch
04 NC
05 Indicator LED
06 Indicator LED
07 PWM for one Headlight Driver
08 PWM for the other Headlight Driver
09 NC
10 NC
11 NC
12 Tempature Sensing Circuit
13 Voltage Dividing Circuit
14 Gnd
Ok, With the info we have collected, I propose the following approach regarding the MCU's. Please chime in with an concerns, thoughts, better ideas, etc.
The above is dependent on Toykeeper's and Garry's approval. They will need to nail down what they want to do regarding:
In the mean time, I will get some temp/voltage readings and finish the work on the thermal path (AR coated lenses have arrived). Do I nee to change resistor in the thermal circuit to increase voltage? Right now it looks like the .2x volts will be the target voltage at which the FW would step down a mode? I'm guessing not because it is a fraction of 1.1 (e.g. .28 volts would be about a value of 65 in the FW).
EDIT: Plan outlined above is not viable due to how stock MCU is turned Off (Long press).
Well stock modes were: wide led on, narrow led on, both LEDs on, both LEDs strobe, then off (I think). Nope, back to wide led on. It's a press-n-hold from any mode to turn it off. So is that close enough to the Attiny's FW to stay "aligned"?
-Garry
Stock modes are as follows: wide beam on, throw beam on, both beams on, strobe with both leds on, ... repating ... Long press in any mode turns light off. There is no off mode in the cycle.
Wait- if the Attiny were put into it's strobe mode that would throw off the "alignment", right?
-Garry
OK, good info Garry and ledoman. I think my idea needs to be scrapped. I got nothing at the moment. Anyone have any good ideas?
EDIT: What if we toss the stock MCU and just use one pin on the Attiny for the indicator LED's? It could blink one or all of them when voltage gets down to a certain level. Maybe faster as voltage gets lower.
For anyone interested in some of the circuits outside of the drivers, here is a very high tech diagram.
The dots are thru-holes. They are just from memory so there may be some I forgot. Pin 3 connects to the Momentary Switch.
I think that we can control the stock MCU with a different, relatively simple, circuit. Whether you’ll want to build one is up to you. I’ll hammer something out and post it in a minute.
I think that a “monostable multivibrator” is the tool for the job if we want to turn on the stock MCU when power is applied. - Multivibrator - Wikipedia
You could certainly build one, and it wouldn’t take many components or much money… but you can also buy one in an IC for <$1. I specifically glanced over the datasheet of the SO-16 packaged 74AHCT123AD,118 ($0.40) and it seemed suitable. I think that at least 2-3 external components (at least one cap and one resistor) will be required. At a glance the SSOP-8 packaged TC7WH123FUTE12LF also looks suitable and is smaller.
