This is annoying, I absolutely can't get the pill out. The one in the pictures above had the 2 holes to unscrew it, mine doesn't have those :( I may make them myself, just drill them into the pill so I can remove it.
Thank you Bose, exactly what I needed. I'll contact BLF member, E1320 and see what he thinks. Maybe see if he can upgrade my USB/charger flashlight too I got from IOS.
I dont think this light uses a screw in pill / retainer design.... Looks more like its pressed in. If that is the case, I am not sure how to get it out.
The JM07 doesn’t use an adhesive, it has a paste, if you unscrew the LED it will move around some. I will just use a soldering iron and solder sucker, never had an issue.
I do a lot of driver swaps and have had small components on the back side of the drivers fall off while trying to desolder them from the pill. If you don't plan on reusing the driver it doesn't matter, if you do simply cutting the solder points with an x-acto knife keeps the small components that may be attached to the solder point that holds the driver in from falling off. .
I never understood why Hank used the 7*7135 2.5a on this great flashlight. Seems to me it should be able to handle the extra heat generated by a 8*7135 2.8a. Heck, even the USB Charger flashlight I recently purchased from them has the 8*7135 2.8a behind the XM-L and makes a big difference.
I’d bet it’s the reflector that makes difference, not driver. OTF lumen difference between 2.5A and 2.8A is less than 100 lumens, at over 500 lumens that difference should be unnoticeable.
