I really tried but I don’t even know if my thoughts are making sense so I let it go for now. Maybe I can re-read again a few times later to make more sense of it.
Thank you sharpie for bringing attention to the matter, I don’t know why others are spamming what could be a very informative thread where new improvements could be made with drama when they have nothing to contribute nor do they attempt to understand the context of the subject matter. (wight excluded as I don’t see his posts as derrogative meaningless spam, but possibly a lack of communication via impersonal internet pixels) It really just puts a bind on a guys like me flipping back and forth sifting through their trash to find the information I need.
I am looking to keep it simple, so I will order a couple old revision 2 led 2 resistor pcb’s in hopes that I might someday actually do something useful, that works properly.
I’m so out of my league here. I have to try, rather fail than give up.
Your saying that I (we) need to know the resistance in the tailcap (overall regaurdless of led selection and quantity) to know what value resistors will need used in place of R1/R2 |OR| which value 1/8W resistor needs jumped from positive spring to ground ring on the battery side?
I have tried a few different resistors on the spring side, lately I have been stacking on C1 but either way it is the same deal with mode switching when hot, so I think swapping R1/R2 would be the ideal way to go about it.
So if I was to change resistor values for R1 and R2 it could potentially bleed enough current to match the needs of the tailcap leds, and at the same time work as a voltage divider for the MCU?
What I am thinking you are saying is that we need to bleed off, as close as possible, the same amount of current that the leds need to stay lit, so the power is being used and not backfed into the caps/mcu causing malfunctions?
Let’s say I am using these leds:
http://www.digikey.com/product-detail/en/150080BS75000/732-4982-1-ND
With a Vf of 3.2V, > and looking to run these leds at .08 mA < subjective, rated 145mcd@20mA.
12,500 ohms total
I am lost.
MattLward
“Oh, I like where this discussion is going. I have been going back and studying basic electronics, have not had to since university in about 1985. I like the PFET idea, but I am not sure there will be enough room on a 17mm driver. Please continue to explore away.”
There is a couple MM height in most pills we could take advantage of. If there is room for traces on the board it could be possible to eliminate the heat tab trace since it’s already connected through pins, and stack a pFET 180* on top of another component bending the legs, you’d have to use a to-220 package or something with legs.
