I highly recommend wrapping the drop-in with foil as well… Just wrap aluminum foil around the base of the drop-in to make a tight press-fit with the body of the host. Just make sure you don’t get too much foil where it can wrap under the pill and create a short…
This will help with transferring the heat to the body of the flashlight as this drop-in will get HOT quickly on high…
Those are good to start with. Still wrap them in foil like keltex78 showed above when you get them. I believe the 504b needed less wrapping of the drop in. I had the 504b from DinoDirect in silver and if I remember correctly it was decently driven @2.0A. Very good starting points
I think DD has a coupon code out now that gives some $$ off. RETAILMENOT10OFF.
Got 504b in yesturday with batteries from manfont all on the same day. seemed weird that it was the same day but worked out for me. awsome light but i think expected more. It seems like thin metal and my tail button was ripped. i also dont like how hard it is to push it on since it sits lower than the bottom of the light. still way brighter than my surefire 6px pro
