Ah, right.
XHP35 HI doesn’t have a tint shift either. I guess the main reason would be price.
ADDED:
Maybe tint selection as well. Maybe longer runtime / turbo time? XP-L will surely not need a thermal stepdown. XHP35 HI might.
The no-PWM linear driver in the K1 should be a bit more efficient than a 7135-based PWM driver. If the 7135 design has multiple channels though, it’s only a small difference.
A direct-drive FET is also frequently a nice addition, to increase the maximum brightness on lights which can actually handle the extra power. It’s mostly just for turbo use though.
Compared to a linear driver or a linear-plus-direct-drive hybrid driver, a boost driver typically is more efficient in the medium modes. However, it’s usually also not able to go as bright as a FET turbo, and tends to be less efficient on really low modes too. So, not as good for moon or turbo, but usually more efficient at most of the levels in-between.
There are some known cases where a boost or buck driver ended up being less efficient, like how the Lux-RC 371D driver is ~30% less efficient (even in medium modes) than a simple amc7135 driver… but that doesn’t seem to be the common case.
Yes, the difference is the driver, since it’s 12V the driver needs additional components which makes it more expensive than a regular 4V driver.
The XPL-Hi and SST20/40 are easier to drive, that will probably be the reason they are already available.
But the difefrence between SST40 and XHP35 probably won’t be very much, apart from the fact that the XHP35 HI will throw farther since it’s domeless and does not experience the bad tint of SST’s
A wider beam (The Osram throws like hell, but the hotspot is very tiny) a better tint, more efficiency, more usability, that’s my main reason to wait for the XHP35
I’m a huge fan of lineair drivers, simple, cheap, small, do the job more than adequate, very robust/reliable, efficiency is fine. And although it has not been proven to occur often, I fear for voltage spikes coming from drivers with inductors (I had a precious 90CRI XHP50.2 killed by a KD boost driver).
So, out of curiosity I noticed a fair amount of people on r/flashlight have been mentioning getting shipping notice for the lights going out as early as the 30th of November as well as receiving the light in the mail. It maybe my paranoia but I also placed an order once the K1 dropped on hank’s site and my order and payment has been confirmed almost 12 days ago by paypal….
Am I just overthinking things or have I been overlooked or missed in the shipping of the light ?
90 CRI XHP50Bs are precious? Arrow has them in single quantities (for some CCTs). Arrow doesn’t have free shipping with no minimum anymore, but if you need $50 worth of stuff….
I have lots of lights with linear drivers. They work fine, but they contribute a lot of heat, which has a significant impact on sustainable output for a lot of the smaller EDC lights they’re used in. The K1, with its large surface area, thermal mass, and battery compared to say, an FW3A is not a terrible application for a linear driver… I’m just tired of them.
I’ve observed that with some lights as well, but Zebralight seems to do it well with one test seeing 319 days for an H600Fd III on its lowest mode and another still going with an SC62w at 339 days. I’m not expert enough on the subject to know why others fall short, but low modes aren’t a priority for me for a thrower. If Noctigon made a boost driver EDC light, on the other hand…. Maybe I shouldn’t have skipped that Wuben TO50R HC group buy.
I ordered my K1 in black with W1 on November 29, 2019 03:29:04 EST. It is still processing on my account. I do not know when will mine ship out, but on Hank’s site said ship before December 15th.
For a subjective impression, I have a 90 CRI XHP50B in 5000K in an Armytek Wizard Pro. The honeycomb TIR means it doesn’t have the usual tint shift issues, and otherwise the tint looks a lot like a 5000K LH351D (slightly green, but not bad).
Aww man. I was hoping for a miracle rosy hi cri emitter. Sigh they are so hard to come by. The XHP50.2 4000K in my Olight H2R Pro was one of the nicest, rosiest 5D emitters I’ve ever seen and it measures 77CRI and a –0.005 DUV. A subsequent H2R Pro I bought had disgustingly green tint. I would like to know how Olight procured the original batch of XHP50.2 as I would love to buy a bunch of those emitters.
Ordered K1, W1, Dark Grey, Dec 2.
Received shipping email from Hank, Dec 6.
Tracking shows the package really was shipped Dec 6, unlike so many Aliexpress vendors, or Banggood, or Gearbest……
My interest is much different from most of the comments above. I see no point in taking an excellent thrower and negating the strong points with emitters that generate a wider hotspot and more illumination off axis. I don’t have it yet, but I bought the W1 version and expect it to do exactly what I want.
And yes, I do have a practical use for this light — I boat at night and want a light to identify markers in the water at long distances without adversely affecting my night vision by lighting up the white bow of the boat. This is the perfect light for this purpose — good price point and small form factor! The ability to charge the battery without removing is helpful if I need a quick charge while at the helm.
Would I like it in a warmer tint? Sure, but not at the expense of a tight beam and long throw.
FWIW, ordered K1 W1 in dark gray on 12/1 and do not have a shipping notice yet.
Spill is very soft, I have several lights with White Flats in lesser sized reflectors and spill is among the least obtrusive of any light I own. (all 250+ of em!) Should work great for you Hollybrook.
Lights are supposed to ship by Dec 15th as I understand it from the site, I ordered on the 29th and of course it hasn’t shipped yet. Looking forward to it.
