Yoiks!
If I bought the light from Amazon, tried (several) standard 21700s, and it wouldn’t work, I’d have to return the light as defective. How could I or anyone else know it would only work with a proprietary cell?
Yoiks!
I’ve bought several olights. They finally get the neutral>cool white and then get greedy on a $30 battery?
It’s probably only part of the story, but yes. My guess is that it’s also easier to manufacture that way and they save 1-2mm in diameter.
@Olight: I have a regular M2R. I bought it because I liked the UI and that you for once did not opt for a proprietary battery design. The regular M2R is very well executed. It did not fail me once.
But I don’t see the “Pro” in a “tactical” flashlight that can’t even be used with some other 21700s. Nothing “Pro” or “tactical” about this. Won’t buy.
Just seems silly, I purchased just a little while ago, going to be cancelling order first thing in the morning. Don’t care about the charging, but if the light does not work with anything but the proprietary battery that is a deal killer, bad move imho!
Wow, that’s pretty bad. I guess I would understand it if the cell needed wasn’t $30. They wanted to do something that required a proprietary cell? Okay. Still idiotic but, sell the cells for $5 a piece when ordering the light. A guy could stock up on 4 or so. Even though that is still a crappy thing to do. That is next level genius right there.
Still trying to see the logic in posting it on BLF. They should have known the term “proprietary battery” wouldn’t sell many lights here. I am a gun guy as well. CZ is one of my favorite makers. If CZ told me they came out with a new 9mm pistol but it will only shoot their ammo at 6 times the money of say, Winchester ammo, I’d start buing Hi-Point instead. Okay maybe not Hi-Point.
Edit: Question. Will Olights proprietary cell only be able to be charged by the magnetic charging dohicky?
The cell looks to be the same as provided with the Seeker 2 Pro, in which case I can verify that with a small neodymium magnet placed on the (+) end it can indeed be charged outside of the light… You obviously still must use caution because it can quite easily be shorted.
If it is like the 18650 it will charge in any charger that will accept its physical size. Even if they were less then $30 I’d think twice, I have two of the 18650 cells from them, both have only seen a cycle or two, and one will not run turbo on my m2r, the other runs it for a few seconds, I assume voltage sag as the light is fine with different bats.
I will say I’m very pleased with customer service, emailed them for confirmation of proprietary only, asked they cancel my order if correct. Answered my email in maybe 30 minutes, confirmed correct, asked if I still wanted to cancel, I confirmed immediately. About an hour later I had the refund.
I’m sad though, would have liked the light for my rifle.
On a different note:
5 or 6 people in the Olight Facebook group report the light not turning on - after charging, the status LED in the switch turns green but nothing happens if you try to turn the light on.
According to the video M4DM4X posted, every single light is tested before shipping out (see Olight M2R PRO Warrior - how its made (a trip to china)) - if that really is the case it would mean that the lights basically die after they at least had worked in the QA.
From what I have heard, Olight has excellent support, so this probably won’t be a big issue. Just something to be aware about if it happens to you.
Edit: More people report of duds on Facebook. Count increased to 5 or 6.
I’d suggest that they check with another battery before returning it, but….
People did and the light seems dead. It’s a few more now, I would guess around 8-10 in that group. One report where the light worked for a little while but then died after the person started to use the tail switch more often. That person also crosstested it with the battery from the Seeker 2 Pro without luck. Not sure what’s going on.
It’s Sean still trying to figure out what batteries his flashlight takes?
Loving my new Camo M2R Pro …
Congrats! Each camo is unique in patterns.
