It shouldn’t be noticeably slower. There are several videos of the GT mini online. Maybe you can compare yours to the ones in the video. I think it should be about 3 seconds from top to bottom.
The original MT09R driver had a much slower ramp than Narsil, like 5 seconds. I’m assuming you have a newer driver that is running narsil.
I did get to measure candela, it’s 105kcd so that review seems to be right on with my sample. I have a light box but it’s not remotely calibrated so no way to measure lumens.
To have mines specs posted together incase of future searches.
Neutral white, 30Q, 3.35A, 105kcd
I just checked the ramping for D4, D4S, GTMini and BLF Q8 just now. They all work practically the same in terms of speed. Up and down. The differences are very minimal.
I’m not sure if I’m doing anything wrong, but yes there seem to be relatively significant variance between samples ( I have tested a GT Mini NW and a CW). Using a UT210E meter and a short piece of copper wire and a VTC6, I get around 5.8amps with the GT Mini NW, but only 4.5amps with the GT Mini CW).
GT Mini CW on the left ; GT Mini NW on the right (both on max Turbo and both using fully-charged batteries)
not sure if you can notice the NW seems a bit clearer…
The ramp speed, bottom to top or top to bottom; for my Q8 & Mini GT are about the same. The Q8 is slightly quicker at just under 3 seconds. Mini GT is about 3 seconds.even.
How do you like the GT Mini NW vs. the Sofirn C8A? I’d prefer to have a side switch + ramping mode, but at 2x the price of the C8A (or C8T) it’s tough to justify.
The C8T is the one with the XPL-HI. It gets close to the output of the GT Mini, but it’s reflector is smaller so it won’t reach as far as the Mini. You probably can’t see the difference with your eyes anyway.
The Sofirn C8T is only NW, so I assume you are okay with that.
You do lose the nice features of ramping, battery check, etc…
If you need a small thrower, money is tight, you don’t need the fancy features, the Sofirn C8T or Astrolux C8 with XPL-HI seem like good alternatives.
Anybody having issues with their light not coming on I got two lights one works fine the other the green button light blinks 3 times and stays on but the light doesn’t work.Working GT Mini - YouTubeNon working GT Mini - YouTube
I posted two videos so you can see the difference not sure if anyone else has had this exact problem.
Yes i have a switch problem and a few others also, i mailed Neal and he agreed to send me a new head so im waiting for that you should do same, clearly a few light sadly have some sort of issue…
The LED might not be attached to the mcpcb well enough. It seems the driver is working from the 2 blinks, but no 2 blinks from the xpl. I assume battery check works? We have already seen one led that snapped off the mcpcb as well as one that turned blue due to poor contact.
Perhaps a list with all those that have problems with light and the status should be added to the main thread to keep track? Like for me i wait for a new head so i will update once i get it hopefully not too long wait.
From The Princess Bride, with Andre the Giant. The priest had a speech impediment… it was funny, having kids is probably why I watched it. Multiple times.
