+1 Mine weren’t centered very well either so when I beefed up the tail assembly I adjusted the reflector by removing the driver screws, loosening the reflector screw, then using my finger to hold down the center of the reflector while tightening the reflector screw. If you don’t hold the center of the reflector down while tightening the reflector screw then the leds will be off center again.
The LED centering on my Q8 is actually perfect. Staring at it for a while and I can’t even find something to adjust so I’ve not touched the reflector just yet.
So the tailcap screws are M2.5? I wanna try bronze screws on the tail end to see if it makes any difference.
Yes, tail screws are M2.5x5mm (including head) and driver screws M3x5mm.
Maybe unscrewing the driver screws and screwing them right in again while pressing the board with some force will place the driver in at least good enough position without any underside gap at the screwing points. Maybe it is not that important to widen the holes?
Without a zoom in camera pic, I didn’t think mine was to bad.
Reflector movement can be Up, Down, Left, Right, clockwise or Counter clockwise. After looking at this I think mine needs a clockwise tweak.
Does the gap shown between the centering rings and led corners dictate the maximum movement possible?
Never mind I answered my own question. It is “very” tricky to fine tune led / reflector centering, and be able to hold steady while tightening the screw. To bad those centering rings weren’t a tad smaller (closer fit). Looks like play around led & a little play between centering rings and refector.
Just drilled out the driver boards to 3mm, and retightened the screws.
it makes a noticable difference, now the Q8 that was the dimmest outshines the other one.
Happy with the result, waiting for my solder paste to arrive to be able to put in lexel’s driver.
I have some brass screws for the tail cap on the way along with some wafer head screws for the driver. I’ll wait until then to open up the holes for clearance, right now my Q8 is already roaring compared to stock.
These are the brass screws I got for the tail end. Allie has some decent offerings for these, but they were all for 50+ pieces, and at most I will only do 2 Q8s so 10pcs for $1 is fine. Then these are the wafer head screws. $3.50 for 25 pcs is a lot, for $1.50 more you can get twice as many, but again I only need so many for myself. Taking a gamble on the height of the head, but most of these wafer head screws for laptops seems to have a pretty small head thickness and I can’t see them protruding higher than a button head.
Probably not much. I did the mods one after another and measured lumens in between. No measurable gain from adding wires to traces - I did this mainly because I wanted to have a wire loop for current measurement. Bypassing the springs afterwards brought 1000 more lumens.
It’s no longer a concern, now knowing that the original screws sit well below the height of the brass ring.
It just means that when choosing alternative screws you need to be aware of this potential issue, and be sure to choose ones that also sit well below the brass ring. Hence the interest in “wafer head” laptop type screws.
It would only become an issue with the original screws if they came loose.
Wow, wish I found those eBay brass screws earlier - been look'n for those for a long time now. The heads are lower profile than standard pan heads - "round pan". The head height of the M3's is 1.7 mm should be about even with the brass ring. so should work for the driver.
For the springs to bypass, I'm yanking out the inner springs - not needed, just get in the way. They are real thin, literally I'm using a tweezer, work them out near the base of the outer spring and then rip it of the the pad - no damage on the one Q8 (4 springs) I did. Not eve much solder holding it down.
