The Q8 is actually the biggest longterm test of overdriving leds BLF-style since we started doing that in 2013. I have always wondered if 3A leds driven at 5A would eventually fry the leds, that never could be tested, and so far so good
The battery drain (parasitic drain) on the Q8 should be super tiny. It should take many years to drain the batteries. You can also turn off the switch lights to reduce the drain even more. Of course, if you are not going to use the light for a long time it’s best to turn the battery tube to cut all power.
Have you measured the drain on your light? What was it?
Parasitic drain is the draw of amps (power) when the flashlight is off and the processor goes into a deep sleep mode, cutting as much power consuming features as it can, but still able to wake up when the button is pressed. Here’s the measured numbers on full or near full cells, after being off for more than 6 seconds:
with switch LED on: 135 µA
with switch LED off: 22 µA
In switch Lock-Out mode, the switch LED is off. There’s also a quick trick method to turn off the switch LED when the light is OFF:
from OFF, press&hold until moon mode comes on (or hold longer)
then quickly release the switch, and quickly click to turn the light OFF
the switch LED should be off now even with the main LED off
To put it in perspective:
22 µA takes 5 years to drain 1,000 mAh, so with 4 3,000 mAh cells, it could last over 60 years, in theory of course
135 µA with the switch LED on takes 10 months to drain 1,000 mAh, with 4 3,000 mAh cells, it could last over 10 years
When the light is first turned off, it continues running the processor for 6 seconds, then drops into it’s low drain, deep sleep state. The amount of amps is somewhat dependent on the cells, so partially depleted cells, and cells with higher resistance will have a lower parasitic drain.
That is not how it should be, there may be a current leak other than through the driver electronics. I’m curious if others have the same observation. If this unexpected high drain is a general feature of the Q8 it is wise to physically lock out the light when not in use, which would be a pity because Tom put in lot of effort to make it so low.
I have a total of 6 Q8’s - most for emergency lights - we loose power often - all sit for months at a time without any unusual drain. They all have been in use since shortly after the group buy.
If you want to measure parasitic drain, you need a digital multi meter. You can basically do it like this:
Set your meter and test leads to milliamp. Then take a battery and touch the positive end to the driver ring, then attach the meter from the battery negative to the driver ground. You should be seeing about 0.12 milliamp with the side switch lights on.
If it’s way higher, then you have a problem with the driver or a short somewhere.
I would think heat would be the biggest issue since the clones don’t use a DTP mcpcb, plus the shelf are usually paper thin if it even has a shelf.
Check out this video David Sunshine did a while back. https://youtu.be/efl0R63-ik0 I think he piggybacked a new driver instead of swapping it. He has a lot of details.
What I’m wondering is how the battery got down below 2.8v. This is the cutoff voltage. The driver should not draw any power below 2.8v. If it did, something seems wrong.
Does only one of your three Q8s drain the batteries fast? Maybe it has a defect in the driver? I don’t know.
Doing a drain test might give some answers.
Maybe the MCU is not going to sleep after 6 seconds like it should? I’ll ask ToyKeeper.
Yeah, I guess that makes sense. You actually need to MCU to be operating and taking samples of the voltage in order to determine whether or not it’s above or below the threshold and that process is just going to create increased parasitic drain.
