Yup, closed room, goggles, fire extinguisher at the ready.
M9x0.5 is odd but found on almost all security camera/fpv camera lenses and laser lenses, it seems to be the standard for those things that need fine adjustability of optics.
I want a good cooler that would be standard for all my testing, for better repeatability
The NH D15 is basically the best cooler that wonât be a liquid cooler.
those youtube videos does not tell you how many hours you got before the diode degrades rapidly
you overdrive the diode already and any commercial module for laser show
serious quality laser engraver has TEC cooling or does drive the diode at lower currents within specs
The 6W opt lasers engravers only have an aluminum heatsink and fan cooling it.
Iâve seen people get up to 8+ W by cooling the laser in the fridge.
I donât think Iâll be going anywhere near that high, maybe 6-7W at most assuming the crystal doesnât burn up at that power.
My cooling should be significantly better than what opt lasers has on their engravers anyway
Those goggles are OD7+ so theoretically they should reduce the 6W of laser down to 0.0000006W (.00006mW) which is safe.
That is of course assuming the laser doesnât stay on the goggles for very long or it will burn a hole through.
In the above links I posted this Sam Goldwasser sez that laser glasses/goggles which are too restrictive are actually dangerous becuz ya canât readily see at times where the beam is projecting, ending, etc. So the propensity is to do a quick sneak peek. Thatâs when apparently some of these eye injuries have occurred even from people who really know better.
It appears the more powerful the laser the proper goggle fitting process encompasses some touchy fine print.
Hey Iâm just glad Endy isnât gonna invite me over to sing âCandelas in the Windâ while he fires up the scary sukkah. :person_facepalming:
I do everything in a closed room so as long as my eyes are safe it should be ok.
If the beam is concentrated I can still clearly see where it is, and if it spreads out past the focal point it ends up being low density and not capable of starting fires.
Fires and blindness are the main two safety concerns
JMO, butt I didnât like it much when it was said to me âtheoreticallyâ when it came to things that can jack me up as they handed it off to me to try out. Ya know, bang, bang things. :cowboy_hat_face:
Ok understand. Now Iâm curious though about sumthing. How do you absolutely KNOW that this particular pair of glasses will protect your eyes under the power levels only you really control? I assume the supplier sez that this particular diode at this particular top power range requires this minimum level of eye protection - and presumably you believe them. Or not?
However I surmise that you may exceed that range, maybe? And if so how do you determine watt glasses covers even inadvertent mistakes?
Ok. Enuff what ifs.
PS. Fires, blindness, and loss of love life. Hmmmmm. Iâm not sure this is the right sequence of priorities for me. :laughing: :+1:
They are eagle pair glasses which according to my research over on the laser forums are a top brand.
Based on that I would trust the OD7 rating is true.
If you search up the OD scale you will find that level 7 is a 10 million reduction, which brings my 7W 450nm laser down to less than 1 microwatt.
Thatâs a lot less than the 1-5 milliwatt laser pointers that arenât dangerous to eyesight.
I think you need to be in the tens or hundreds of milliwatts to cause damage.
I want to try messing around with my own LEP. I am new to lasers. I have many questions maybe I could get some help with? (should I make a new post?)
The âthrough holeâ method seems more easier to DIY compared to the âreflecting methodâ that the Acebeam W30 uses. I am leaning towards the âthrough holeâ method, but am concerned with the cooling problems the crystal may have. I am not trying to set any records. I just want a decent LEP that is better than the W30, so ease of build is more important.
It is said to avoid back reflection. But will the lens used to focus the laser pose any potential problems?
If I am using âthrough holeâ how thick should my crystal be to be most effective?
Is the NUBM44 a good choice even if I only use like 1W or less? Could I power it at like 1mw to just run tests and focusing?
What optics should I use to have very good focus? I want my optics to be reliable so I dont have to worry about another factor.
Could I technically buy a standard âlaser engravingâ module and just use it? Is there some special extra optics that a LEP needs?
Based on my drawing of the âthrough holeâ method, I have a collar and a beam dump and seems quite simple to DIY. Any foreseeable problems with my drawing?
I am quite concerned with safety so I added a beam dump, are there other possible problems?
Price is not a concern for any components especially if it increase my chances of success.
2) no idea, the research papers only talk about lumens, not about intensity, so there really is no information on that yet.
3) I donât think you can power it low enough to get only 1mW.
4) some professional grade plano aspheric lens, but that would be very expensive. Thorlabs has a 100mm one for about $1.5k
5) those 1W+ laser engravers are usually using a nubm44 and laser focusing lens.
6) drawing looks about right, except if youâre using a crystal then it will likely be only a few mm in size so you need a pretty precise mount.
7) you need to calculate the diameter of the laser beam at the lens based on the divergence, since the laser lens will focus at the phosphor and spread out afterwards in a cone. Your mirror or laser sink will probably need to be much larger.
Regarding mounting the crystal, what ideas do you have?
Is it fragile like LED phosphors or something like a pcb?
Is there some kind of glue I could use?
What do you think the industry uses to mount these crystals? Even if it is mounted on a flat surface, how would it even be done?
I will be purchasing some crystals from crytur.cz too. Would you still stick with crytur.cz if you had the choice of something else now that you have it? What about the 3x3mm size?
An idea I thought of is to glue the crystal to a piece of thin glass.
Wel if you go with a reflect design instead of a through design it will be a lot easier to mount, because I think they sell them already bonded on a piece of metal.
With the crystal alone I was planning on machining a copper cooling block with a hole through it and then stiking the crystal over the hole with some thermal epoxy.
No idea how it is usually done in industry.
Yeah, I would stick with crytur. 5 pieces minimum though, so it will be about $250 for the 3mm ones.
Why did you choose the bare crystal instead of the mounted solution? If you have already asked them, may I know the price of the already mounted crystal?
After doing additional research, I will be going with the reflective design. A crytur rep gave me some general direction (reworded myself):
Power is unlimited as long as crystal is below 250degC
Generally, a transmissive design should be under 10W per mm2
Generally, a reflective design can be around 25W(a guess based on wording of reply) per mm2
Here is a 2018 test I found comparing reflective and transmissive
A few other articles also show that an issue is thermal management.
I have a nice high res thermal camera, do you think the intense brightness would affect the readings of an IR camera? It would solve so much guess work if I just tune using an IR camera.
Since power is not the limiting factor like LEDs, we can just keep pointing more lasers at the same spot. I was wondering if a wavien collar would prove as beneficial as it is to LEDs.
