@Hardusvd70 is that stock light without any mod?
Yes both stock. Just got my JM70 yesterday. Did comparison test between the JM70 and UT02.
Hardusvd70 and Nico raised my curiousity just over my natural laziness, so I opened my other 3 samples of the lights and measured the throw - 11 m from the lux meter (HS1010A) and saving the max value:
Battery 4,15 V start My sample - 2180 cd = 263K
1m start / 248K@30 sec
Sample 2 - 1830cd = 219K start / 214K
30 sec
Sample 3 - 1994 cd = 241K@start / 218K @ 30 sec
Sample 4 - 2004 cd - 242K@start / 228K @ 30 sec
My sample again - 2040cd= 246K - at the end of the measurement. Battery was 4,06V.
So my conclusion from this small batch - it is some kind of lottery, yet deviation is +/- 10% from 240K cd cold start.
I’m finally back home and I tried to re-center the LED with this instruction. But when I screw the bezel back I always end up with LED completely off-centre. Suggestions?
Maybe find the proper centering ring ?
What’s the opening of the reflector ?
Without a good centering ring, I had luck with using aluminium foil between the head and reflector. Don’t have this particular light though.
I’d rather not open the head because while I was away my flat got dusty. So I’ll have to do without a centring ring for now.
I managed to slightly improve over factory by positioning reflector, pressing strongly with my fingers right at the centre of the lens and then screwing the bezel. Worked moderately well on the first try, so I guess I can improve it further.
How does alu foil help with centring?
It can fill the room the reflector has to move offcenter. Almost like a big centering ring. If the reflector keeps shifting to one side, you put a bit more on the side it is shifting to.
Might help a bit improving heatsinking too, filling air with aluminium.
This centering ring is perfect for Jm70 xp-l hi , at least fits perfect on mine (old version , no charging).
Anyone thinking of or already has modding the light for xhp70.2?
I’m considering it but want to hear results first.
They have AM33 - 3x18650 and XHP70.2 with same reflector.
