Gotcha…… thanks for the sanity check
got my archer-1a from china!
very impressive small flash light, eneloop works very well, really throws about 50-60 meters.
a tint is in full, pure snow-white, nothing blue, green or purple.
now i’am lookin’ for 14500 + charger from FastTech and like to order the O-rings as well.
the original ones are suddenly damaged as we know, so these are the right O-rings, Kreisler?
Water-tight O-Ring Seals (5-Pack)
which charger + 14500 do you recommend?
o.k., so that’s really a faulty construction on archer.
i’ll try to get 15.0 x 17.5 x 1.25 in a hungarian “water installation shop”.
if those don’t fit too, i’ll be careful and don’t put the archer into water…… J)
why your neighbour doesn’t use the archer?
I live in the city, in a country with no power outages for the last 20 years, my camping days are as good as over, I do not need flashlights either but I don't care: I invent as many uses of them as possible while waiting for the zombie apocalypse :ghost:
Need? Need? What’s need got to do with anything?
Hi Kreisler!
where has gone your review?
can’t find it no more….
I love it when a new term gets coined.
Uh? What is this thread without a title?
check the op, a typical BLF "20$" review with 3hrs invested time&efforts :P
guys feel free to compare and then estimate the monetary value of my immense 70hrs investment, the
Review: Foursevens Preon PenLight Olight O'Pen (2xAAA, XP-G2)
Why no keychain duty anymore?
I can say for myself that Tank007 E09 is a piece of crap as is this one most likely.
Everything is probably glued and hard to modify. Uses a poor driver with an old XP-E emitter. Not even neutral tint and not even XP-E2 or XP-G2.
I’m modding my E09 with XM-L2 T6 3C, coz fuck it, new wider TIR lens already destroyed/dedomed XP-G2 and XP-E. Grind grind and boom XM-L2 fits perfectly to the old reflector
Chunk of copper underneath, driver modified to maximum output. Should be no problem now in case of using lions to not blow up the emitter but with XP-E it could happen lol. Not much boost on NiMh but in the upper voltage ranges it does boost a bit J)
Anybody thinking of modifying any glued Tank007 light, forget it and get yourself a different light, not worth the money and time for modding. The whole driver is glue sealed inside you will have to drill and so on it out. If you even get the head opened since that is glued very very well.
Kreisler always forgets this, Tank007 = glue = avoid them if you want to mod.
They had quite a few in stock, now only 2pcs left.
I'm thinking that Wallbuys probably has more than two in stock, but there are only two available for 48% off.
