You got quoted because I didn't think i could say it better. It would have come out as a poor copy of your words anyway, so I thought I'd just use yours...
Glad you aren't offended. I know people who would be...
I put it in a holster that came with an Ultrafire C3 - thanks to Vectrex for pointing out that this worked, it probably wouldn't have occurred to me to try it. It is now installed in that holster on a cop's belt. I've found a very scary looking picture of the cop but I'll need to ask him if I can use it first. I went for an AA light that wouldn't take lithium cells as the local cops only issue AAs so that was the best bet for him and a light designed for alkalines is likely to be way more efficient on them than one that will use from 0.8-4.2V though most such drivers drop into direct drive with no regulation until the cell voltage drops below the forward voltage of the LED. Which is usually around 3.2-3.7V
A spot of work with pliers would probably make it suitable for belt use (or break it). Like I said, I was handing it on so didn't want to break it.
DX actually do more holsters than I thought. Might get some more though I tend not to use them on my belt. I'd have to get a whole lot fatter to get 80 lights on my belt.
QCG is the place to look for them though it is more expensive than DX. If you browse their wholesale site then email them for prices for small quantities they'll sort you out. They have, or at least had the last time I looked, hundreds of holsters. But if DX have them, you'll spend less. Just looked and they still have quite a few - remember the prices on this page are wholesale ones for a minimum order of $200 the last time I looked - they will cost more retail.
Just cover it up with a black Sharpie - that will not kill nylon. Or dye it black.
Off the top of my head I can't remember whether sodium hydroxide (lye) will hydrolyse nylon or not but I'd not be keen to try it. It would pretty likely kill the polyester thread.
Try bleach first. Less likely to kill the nylon as long as you can live with a white holster. Or try the Sharpie trick - or any other permanent black marker.
I read the great reviews on the P31 posted here and at DX so I bought one. Sadly, mine is DOA.
It looks like the bezel might be threaded to the head but its hard to tell for sure. Two large strap wrenches wouldn’t break it apart so maybe its not a two piece head/bezel after all. The pill appears to be threaded into the head tube but I couldn’t get it to turn with a pair of needle nosed pliers while pushing on the solder joints. Maybe its glued, or possibly not threaded in at all. Hard to tell. Can I drill two small holes near the edges of the board to try and exert more turning force with the pliers? I hate to RMA it and wait a month for a replacement but I cant get the damn thing apart to fix it. Its not the clicky/tail and it flickers when I tap it sharply. During one occasion, it stayed on for about a minute so I had a brief moment to pay with it. LOL! I must say, I do like this light.
Any suggestions would be appreciated.
On another note, thanks for creating such a nice forum where people can freely discuss this fun hobby.
I'm not very good at repairing stuff, but I have found with DX flashlights that it often makes a world of difference to just tighten up the light module into the head and snug up the switch module in the tail. In addition, try swabbing down all the surfaces you can get to with a cotton swab or toilet paper, including all the threads. Hope it might work for you!
I don't have it any more but at a guess you'd have to unscrew the pill from the inside. The pliers trick is what I usually do - a set of circlip pliers is good for this as you'll bend them usually before you destroy stuff. I'd not drill it till I'd checked with a bit of wire that the problem isn't at the switch end. More often than not it is there.
There's some articles on troubleshooting here which may help.
Its good to be here. Thank you for your suggestions.
Unfortunately, the problem with the light is inside the pill itself. There is no way to loosen or tighten it... at least that I could find. If there was, Id be able to remove it for closer inspection and repair.
Looking at my pic of the head there appears to be some rubbery stuff visible below the left hand solder blob at about 7 o'clock.
It looks to me like it could be glue which will make it a pig to shift.
I'd get some needle nose tweezers (DX has lots of them for not much) and try to pick out that rubbery looking stuff.
Next step after that is to put it in a sealed plastic bag and boil it in water for 10 minutes to see if that'll soften the glue as they tend to use hot glue that'll melt.
If that doesn't work put it inside another plastic bag and freeze it overnight then try to shift it.
Thanks for all the great suggestions. I have tweezers and picks but mine doesn't appear to have any rubbery stuff hanging out that I could find. My precision needle nosed pliers are stainless steel and take a lot of abuse. I again applied all the turning force I could possible muster and it still wouldn't turn. I'll try the the boiling and freezing methods to see if that helps.
I assume I need to try turning it while the head is still hot/cold.
It is best to but try to avoid burning your hands. Try freezing first as some of the plastic materials they make some reflectors out of can soften at boiling temperatures - I have a really nastily made MTE light that I ruined the reflector by boiling it. I'd hope it had a metal reflector but I don't know as I didn't try to take it apart.
It is best to try it while hot/cold but avoid burning yourself. I add this because I didn't think it through and have burned myself this way.
Its not screwed in! It wasn’t immediately apparent, but the driver pries out via a small slot at the edge of the board. In prying it out, the two soldering joints that weld the board to the head broke free. Once opened up, I found a small wire coil that had come lose from the board. A cheep solder weld that attached it broke. It cant be soldered back because there is no place to put the soldering iron tip between the board and the coil. I've decided to use an alligator clip as a clamp to hold it in position while I glue it back in place. Even though it will be a press contact fit, pressing hard or lightly on the coil didn’t seem to effect the brightness of the LED, so I think this might work. If not, its time for a new driver.
These lights have excellent build quality but the PCB is very fragile and not very well built. The soldering joints are low quality and very fragile... not just the one that broke on mine but all of them. It probably wouldn’t hurt to bed the circuit side of the board in silicone or rubbery heat sync compound to give it some additional impact protection.
I'll report back after the glue dries to let everyone know how things worked out.
It is worth mentioning that replacing the driver couldn’t be easier. Does anyone have a suggestion for another driver? This will be used only with eneloops and I want efficient high output, not long run times.
Don, thanks for the suggestions. I'll add those methods to my arsenal of tricks should I run across a glued light that wont come apart.
