Its main benefit is it can measure the signal integrity in an abbreviated format if you do not have a 12Ghz scope. It can even measure pin-to-paddleboard resistance within the connector. But I do realize it might be a bit more expensive than most pro-users would prefer.
I have spoken with the creators of this and asked if they might consider making a âhobbyistâ version. But the market is limited, so I do not know how well received that suggestion was. I directly cited the work you do here as an example of the benefits. But then you risk companies trying to use it for QC on production lines â as Iâve seen some companies use the YZX testers you cite.
(The 0.5Hz drift etc. you have the skill to notice, they do not. As a result engineering errors are made on consumer products. âPass/No passâ syndrome.)
Here is a sample of the data it generates:
I share all data from tests I run. If you would like, would you be willing to incorporate that into your results table? I admit Iâm a bit envious of how well you document your battery and cable results. They are very well formatted and presentable.
The only issue I see with USB-C is there are additional things to query (eMarker, certification lookups, length, active vs passive cables, etc) that are very difficult to document in a standardized format. So my own documentation is a bit lacking.
I say âFie!â to that! Iâm technically a homegamer too. Just a lucky one. Please consider writing TotalPhase expressing interest and perhaps they can offer a restricted suite for less.
Actually, it runs a webserver and appears as a network adapter. You plug it in, it adds an NDIS internet IP adapter, and you type in the boxâs private IP address and you do all work through the web browser interface on the box. Itâs all self-contained.
The only reason youâd need any of those utilities is for firmware updates, which are free on the website. The only consumable is the box on the left. It is âonlyâ rated for 10k connector insertions⌠and the box keeps track with a monotonically increasing counter. This is again to prevent fraudulent data from factories when the connector wears out. There are also adapters to cover A-to-MicroB and C-to-A etc. cables. Pins are pins.
Please let me know if you would like to know more about the specifics of what to look for in USB-C cables.
The important part is to independently measure the IR drop (resistance*current at max capacity of 3A or 5A) on the Vbus and GND pins. There are different thresholds for each. (500mV Vbus, 250mV GND) due to data signaling concerns.
All 4 Vbus and all 4 GND pins must be tied internally in the connectors/cable.
Some cables also bridge GND to the shield braid of the cable to get a âfree ground conductorâ.
Some get it backwards and use the shield braid for Vbus, which is VERY dangerous!! Especially if the cord frays.
Some connect the shell to ground, others keep it separate.
USB 2.0 cords are NOT supposed to have SBU wires
SBU1/2 wires are supposed to be âcrossed overâ, like the SSTX/RX pins.
If you just need to do continuity checks, hereâs an open-source Arduino Mega schematic I created. Itâs fairly crude however: it doesnât do resistance measurements since I donât know how to make it accurate enough.
I apologize if I went off-topic.But I really want to help as much as I can.
i hope you will continue reviewing blitzwolf powerbanks.
i pre-ordered one of their latest powerbanks:
do you think you will review it?
(i have the old xiaomi 4x18650 10400mah powerbank, and the single cell blitzwolf powerbank, but have been thinking about something in-between them as well, when this one appeared at a pre-order price of $12.99)
Blitzwolf sometimes send stuff to me for review, I do not know if I will get that power bank.
Due to the amount of items I have in queue I will not be buying it myself.
May I ask how to donate equipment to you? Iâd be interested in your opinion of the Belkin F7U005bt04-BLK illustrated here. (Comment split from BlitzWolf BW-C4 thread.)
Or I can ask Jen Warren (Global Director of PR, Belkin) to send you a sample. I presume they have their own warehouses nearby, and would appreciate a counter-point to my initial criticism of this charger when used with the Google Pixel (Sailfish model).
I found this USB charger, which is unusual/rare because of the horizontal orientated ports. This makes it useful for USB Voltmeters on each port just-mobile.eu/alucharge-eu.html
