Review: Sunwayman T60CS (3 x XM-L U2 | 3 x 18650 / 6 x 16340)
I can't recall specifically but it was while I was testing the current. I removed the tube and only had the battery carrier pressed up against the base of the head. I did see some small sparks but nothing unusual, however, after a few times of this it didn't register any reading on my DMM so that's when I found out the carrier had protection built-in.
This was right after I received the V60C and since I needed to get the review completed at the time, I created a "bridge" with a paper clip to connect the positive tip from the first battery (in series) with the central "leg" of the carrier that routes the positive path.
There are additional details I need to add to this review which will include the battery carrier. Should have that up later tonight.
Cheers,
Tim
Any problems at all with the light, pounder?
Okay. It looks like, then, that with normal use there shouldn’t be a problem. Thanks!
nope…it’s been rock solid since I got it…
I've added full details for the battery carrier as well as completely fleshed out the review.
I purchased some off white plastic hole plugs off Ebay that fit perfectly - except for the prongs that were a bit too deep/long. I have a dremel tool and it took just a few minutes to grind them down for about an eighth of an inch.
Here’s a photo:
Oh wow, that does fit rather well doesn't it? BTW, I can't seem to see your 2nd pic.
I can’t seem to get the second pic to post. I’ve tried over and over again. Is there some kind of limit for new users?
Anyway, here’s a link for the plugs on ebay.
UPDATE: The fit wasn’t as tight as I hoped - the plug fell out after a little jostling of the light. I tried to expand the prongs to make it fit better but that didn’t work. If they made these plugs in 11mm that would be perfect, but I can’t find them anywhere…
I found black 44mm plastic camera lens cap covers on Ebay that work perfectly as a tailcap cover - nice, snug fit. Even the lanyard holes are left unobstructed! How does five pieces for $5.45 shipped sound? Pics:
Sah-weet! Great idea!
