I love the Mirage V11R’s exterior. It’s so military. The camo pattern is cool.
Thanks a lot for the review! Frontpage’d and Sticky’d.
To my surprise, the ring on my V11R mirage, that I hadnt used for a few weeks was stuck.....
fortunately I could get it loose by using a bit of power...
The next problem was that the ring started spinning... uhmmm
So I tried to unscrew the head with 2 mini rubber strap wrenches.. and voila... they came apart very easily..
I didnt have to use much strength..
Once it was apart, I put some lube under the ring, and while I was at it... I wanted to change the XML to a new XML2 T6 4C,
but when I desoldered it from another star, I accidentally dedomed it.. now the tint doesnt look as nice anymore :(
A bit greener.... at least I will keep it as is... and maybe change it in the future.. at least its very easy to open now.
anyway, your Mirage could also be opened easily???!.
I also tried it with my new V11R revolution.. but I couldnt get it open...
Maybe it is because the Mirage is older,and the glue might have decreased in quality over time.
Oh.. and the alu star is 12mm dia
i guess the glue is still too strong on the new V11R... I also haven`t used it much.. as I assume the quality of the glue will decrease once the light has been used for many times/heated up many times..
not sure, just assuming.... that seems the most reasonable answer ;)
For me it has been easy to move apart the head on those SWM M/V 10/11 not blackish:
M11R Tan, M11R grey, V11R desert, Mirage, Ti.
Not easy (or impossible) in "blackish": V10R, M10A, V20A. Not intented in V11R Neutral white
Mine is the black v11r, and I can't open it...but it already has NW, and enough grease, so I don't really care too much.
I just wanted to see if it worked.
Would swapping the emitter to the XP-L HI yield better performance ?
Good question.
I've removed the triple, and destroyed the old XML. Now need to get another led, but I'm in the middle of a move, and don't really want to bother too much. There are a few other lights I'm using.
Maybe I'll replace the led when I have moved and have more time.
