Thank you for this review, HKJ. Picked one up and have been using for the last several weeks with 18650’s (protected and laptop pulls) as well as Eneloops and so far have been satisfied (except for the 500ma output and time with the Li-Ions but I knew this going in)
My new Eneloop AA’s definitely get warm-very warm to the touch, but far from what I would call hot, let alone “too hot”. Not sure what the I4 has, but there are no steel guides “in” the spring, and certainly nothing like Jetbeam’s new “PRO” charger metal guide rails.
All the material fails to list 10440 as supported by this charger. But I don’t understand why they wouldn’t work. Isn’t 10440 just the same voltage as 14500? And AAA NiMH fit in the charger. So I don’t understand why this charger can’t handle 10440 batteries. Has anyone tried this?
Maybe I’m just misunderstanding. But is a 10440 not just a lower-capacity 14500? The charging rate of the i2 is 0.5A, which I imagine is fine.
And the i4 charges would charge two 10440s at 0.750A if you only put two in. There must be something I’m missing or Nitecore’s documentation is incorrect for the i2.
Thanks, HKJ, this is starting to make sense. So the i4 charger can charge at 350mA and 750mA is my understanding. So in the case of 10440s, it would select the 350mA charging even if only two cells are inserted? I guess that makes sense and thank you for the explanation!
rpm. With my limited knowledge 1C is the capacity of the batteries in mA. If a 10440 is rated at 350 mA then to charge them at 500mA would be exceeding the 1C recommendation. What is the minimum charging rate off this charger?
The i4 charger is always charging with about 700mA, but if you put two batteries in the correct slots, it will split the current between the two batteries (This does not depend on battery size).
This gives an average charge rate of 350mA, but remember: Must use the correct slot and both 10440 must be empty.
Generally I will not recommend the i4 for 10440 and I also gave it a note in my review.
I tried it with the i4 and the battery button top will not contact the + connection tab of the charger. They could however be rigged up external with some wire and magnets.
I have just ordered the i2 I want to charge the batteries for my vaping-mods.my batteries are
18650 imr,18500imr,18350 imr,16340 imr.18650 protected,18500 protected.I :cowboy_hat_face: hope the i2 will work well
goerkel…
You’ll be good to go!! I use the i2 with my AW IMR 18650’s and 18490’s with zero issues……
BTW….I’m vaping with a Reo Grand and Mini 2.1 from Rob @ ReosMods.com……Simple, and built to last FOREVER!!
Good Luck!
