@wikiman, I think it was already pointed out above by Shaquille, you can ONLY use unprotected cells in this unit. I also have it and have been using 3400 mah NCR18650B’s in it. I have come to like the build and form factor of this unit.
Yes yes, now I also have it
Nice backup of juice, well made and charge to exactly 4,20V.
wikiman:All above box chargers are for 4 cells. May I suggest you HKJ to test something for 2 cells? For example this one: http://www.fasttech.com/products/1421/10002784/1207400-enb-218650-li-ion-battery-usb-emergency-charger
I do already have one for two cells, but the one you linked to looks good, I have ordered it.
Now the question is if get time to do the reviews (Next item is a Soshine charge).
Can’t help but think that we are all very good at spending HKJ’s money for him. :bigsmile:
HKJ excellent charger reviews! Much Thanks.
Just wonder if I can somehow enable discharge to phone and charge the 18650 at the same time.
I did multiple test but unfortunately it only allow charge or discharge one at a time.
Reason I am asking I am trying to setup cache battery on my bicycle to store energy from dynamo and in the same time power phone.
Also I wonder if charger in your review below can allow same time charge and discharge
USB battery box 4x18650 Coolook PB-2000 [image] This battery box is called Coolook iPower and has the type number PB-2000, it can be found on ebay from a couple of dealers (They do not always include the brand name or type number). The specifications is something like: Battery replaceable. Intelligent charging with indicator to show the charging status. Output current-limiting protection to avoid damage when over load. Can charge most cell phones as well as iPhone and other Apple produc…
And lastly I understand you are getting below charger. I tested it for same time charge and discharge but it is behaving strangely.
Every second it drops and restore output power when it plugged in to recharge. I wonder if it can be fixed?
http://www.ebay.com/itm/ENB-Micro-USB-rechargeable-mobile-power-bank-supply-charger-18650-li-ion-1-5A-/321130099627
Much Tanks!
Just moved this question in to:
Just wonder is there 18650 USB Chargers that allow discharge to phone and charge 18650 at the same time? Reason I am asking - I am trying to setup cache battery on my bicycle to store energy and in the same time power phone / light. I did multiple tests for below charger but unfortunately it only allows charge or discharge one at a time. Just wonder if it can be modified to allow same time charge/power cycle. [image] Also I tested below charger but it is behaving strangely when trying same t…
Much Thanks
HKJ excellent charger reviews! Much Thanks. Just wonder if I can somehow enable discharge to phone and charge the 18650 at the same time. I did multiple test but unfortunately it only allow charge or discharge one at a time. Reason I am asking I am trying to setup cache battery on my bicycle to store energy from dynamo and in the same time power phone. Also I wonder if charger in your review below can allow same time charge and discharge Review: USB battery box 4x18650 Coolook PB-2000 And lastly I understand you are getting below charger. I tested it for *same time charge and discharge * but it is behaving strangely. Every second it drops and restore output power when it plugged in to recharge. I wonder if it can be fixed? http://www.ebay.com/itm/ENB-Micro-USB-rechargeable-mobile-power-bank-supply-charger-18650-li-ion-1-5A-/321130099627 Much Tanks!
Sorry about the late answer, but I have been busy the latest couple of days.
A fast check of the box in this review, looks like it can do it, but the output switch is not working correctly when charging.
The PB-2000 cannot as I have stated in the list just after my "Measurement" heading.
Can the box from this review be used as UPS ?
Please check the date of the review, I doubt this model is made any more.
