Some cheaper plastics will turn brown and otherwise degrade with cumulative UV exposure.
so - given that this thing puts out a lot of bluish light, would it make sense to get a small piece of woods glass and add it to the front to filter that out?
wle
Yes that would help a lot, I have several UV-flashlights that have such a filter, the chinese version is called ZWB2 (and Schott uses UG1)
I tested such a filter a while ago for flashlight use: 2mm ZWB2 filter tested (visible light blocking filter suitable for 365nm UV flashlights)
Your title says Nicore, but link says it’s Nicron.
One of them must be wrong…
right it is nicron, sorry
wle
I have the S2+ with Nichia LED. Pretty powerful. compared to my other UV lights (Kaidomain WF-501B with cheap UV drop-in + Convoy S2 bought few years ago).
Also, you can buy something like this for blocking visible light: 365nm UV-Taschenlampe Sichtbare Filterlinse 1 Stücke Sale - Banggood Deutschland sold out-arrival notice-arrival notice. Along with 18350 tube it will be pretty short light and still giving loads of UV…
Acrylic lens give a little fluorescence in UV, so may add some of the visible light as well.
Edit: sorry, didnt realize that editing can bump the post
I decided to get one of this during a promo flash sale in AliExpress.
It does emit a lot of visible white light (seems to overpower the UV light).
But if I place a ZWB2 filter (I only have a 20mm ZWB2 filter which is too big to fit inside this flashlight, so I only held the filter in front of the Nicron B10-UV), after that, the visible white light is now mostly filtered out, and what remains does look like 365nm wavelength UV (when compared to my Convoy S2+ UV365).
I’ll try to take some pics sometime for comparison…
yes that is what i did too, glue a ZWB2 filter and that fixes it.
what the visible light does is, it overpowers not the UV light, but the light that your test material might make
unless it makes a bright blue glow, like white paper or a tshirt does, you can;t see it in the whitish light from the nicron
anything faintly glowing is hard to see
it’s still a good toy for $10 though
or less
wle
For what it is worth, I contacted Nicron about their B-75 light. It showed up in one of the coupon offers on BLF but doesn’t look like it is showing up on their web page yet. It is a rotating head light with both white light and UV emitters. The description said 365nm in one place but 395nm in another. When I asked about this they said the 365nm was a mistake and the emitter is 395nm. I am guessing that the inexpensive twisty has 395nm too. If so it will limit the usefulness for UV.
Edit: Sorry, here it is https://nl.aliexpress.com/store/product/NICRON-Magneet-90-Graden-Twist-UV-Wit-2-Color-Oplaadbare-Zaklamp-18650-2500-mAh-Ion-Batterij/111575_32833496892.html?spm=a2g0z.12010615.0.0.4dd12017DDxiKL . They have changed the web page some since I first saw it.
