RaceR86:
Old-Lumens:
Carlco should carry something for the XP-G. I use the 10 degree from Fasttech (for XM-L), but they seem to work fine for Nichia and XP-G too.
Who puts five leds into a single light? You modders are crazy.
If you get the TIRs to fit tight in the holder, you can lay it upside down and run some epoxy around them. It's thick enough that it should not leak if the seams are fairly tight.
Great build. Keep 'em coming!
Thanks for the suggestion and info Old-Lumens. Carlco carries lots of stuff, but I don’t know a good place to buy their stuff. I browsed their webpage, was not able to find anything within about the same size (small enough to fit 5 emitters in my light) that I would consider. Old-Lumens, you meant the 10 degree XR-E optic?? Or do you see something I dont see. http://www.fasttech.com/products/0/10001329/1108201-10-degree-angle-optical-condenser-lensoptic-for-cr I see they also have 8-degre optics (with holders) http://www.fasttech.com/products/1606/10001329/1250300-8-degree-angle-optical-condenser-lensoptic-with-ho But both of the above are much larger then the ones I used. Yesterday I had the opportunity to use it outdoors at night. After that my conclusion is, I will keep the TIR optics I use! The flood is just fantastic. Perfect for walking in the nature. Even great for indoors use and caves and stuff. Everything around you lights up nicely. Normally you have to point a flashlight around. Even a P60 type reflector gives you a tunnel vision. But the Fat Flooder just lights up everything in front of you like it was daytime. Its not like any other flashlight I own. Quite a game changer! I just have to redo the front and do some changes to it, I think it will become quite sweet and unique once its properly finished (It could take some weeks, since I have several other small projects running). Until then Ill enjoy it as it is.
https://www.fasttech.com/products/1187501 15 degree
https://www.fasttech.com/products/1606/10002020/1144800 30 degree
CNQG had the same thing only 45 degree.
Nope, probably won't fit five without shaving them down a little.
RaceR86
(RaceR86)
May 12, 2013, 11:24pm
22
yes, those are the 15 and 30 degree optics I have tried. I like the 15-degree version. Got 5 spares lying here. They sit nicely around an XM-L (unlike the 10 degree stuff I got from another place).
But even if I were to file away that small ring around them they would still be close to 17,7mm wide…
It should be possible to fit 4 of those though. Something I will have in mind if building a different light…
I know 4 emitters @ same current would be better for slightly more throw, and those tighter and larger optics would help too. But I have come to like the little fat flood monster and its beam. Its unique and got character, quite different from other “floody” lights. Very useful for lots of close up stuff…
