The schematic is OK! Thank you! The reflectors are from Dealextreme http://www.dealextreme.com/p/18mm-12mm-aluminum-textured-op-reflector-for-cree-led-emitters-4-pack-14598
The stars are 14,2 mm from Kaidomain http://www.kaidomain.com/product/details.S009892
The heatsink was from an aluminium rod with 32mm, glued with artic silver Epoxy, before glue
i filled the hole in the pill with a copper plate!
@ daysoft - welcome to the forum, that's a really cool mod, well done for thinking out of the box and coming up with a new idea. You're mod has gien me some ideas for this little beast of a torch.
i think this torch would work well built in a similar way but with lower current LEDs running of the 3AAs?
Btw Essexman, if you are the same username on DX you can't use a single C cell in the light unless it's a 3.7v li-ion cell as it doesn't use a boost driver. You may well know that already but I wouldn't want you buying it for that purpose before finding out for yourself.
I built the same torch with one xml and three Sanyo Eneloop XX for a friend.
With the normal Batteryholder was the current at the tailcap to low, after mod it with copper sheet and better springs the current went up to 2,6 Amp. ( Enough to drive the xml almost to full output ) The original refector had an good throw.
May be i built a second one ( i had one SAIK in spare ) because normal AA batteries are useful in Europe, where
