I am still a novice when it comes to building lights (so far built a 85cri-nw with Convoy S2+ and a cyan with Convoy M1). I am in the middle of building a triple r9080sw45 219b (thanks clemence!) using this host. I plan to run it at a conservative 2A (I hate turbo modes and my country has warm climate), and the experience so far has been daunting.
I couldnāt use Sofirnās fet driver as the current would be too high. So I thought I would go with a Nanjg 105C. Could not afford a Pomona soic clip, so hand soldered the attiny and flashed momentary star firmware with some modifications. Now the thick driver retaining ring of this host refuses to fit over (the 2x7135 heatsink tabs on the backside of the driver obstruct the ring). So I must manage this somehow using excess solder. And the spring of the 105C is too short, so I have to buy some new springs :(.
The light engine part is complete though, but that was not easy either. For that I first reflowed the 219s to the dtp board, then attached wires, then screwed on the reflector to the board (this must not be too tight), then applied arctic alumina to the pill, then pushed the reflector-dtp-wires assembly inside (making sure the wires come out properly through the holes to the other side), then tightened the bezel and finally screwed on the center screw (this must be tight for good thermal transfer) going through thr reflector.
Unless there was a glitch in the system? Kept coming up as a new post? I read the same post 4-5 times and refreshed in between by hitting Recent Postsā¦.
The host is a bit tricky to put together but iām surprised you needed a longer spring. Is the driver sitting in the usual spot since you couldnt use the retaining ring or did you solder it further back? In other lights sometimes people just take some material off the inside of the retaining ring to make room if itās close.
+1
I edit the crap out of my postsā¦ My BLF account has this weird bug, it automatically edits my posts with a lot of mistakes so I keep having to go in and correct them
Thank you. Whatever flashlights I have built would not be possible without this forum.
I have not soldered the 4 wires to the driver board yet, but just eyeballed that the factory spring would just touch my flat top cells (spring begins where the threads just end), but I will double check.
EDIT1: I was wrong! The shorter spring also works. And I have completed building this flashlight. While light output from the 219B triple is average at 2.4A, it actually renders things better than sunlight in red region (tested with wooden doors, skin, tongue, red multimeter leads, red buckets). Totally puts my 85cri Cree T5-5D1 to shame, which despite having a rosy tint looks orangey. Thank you JohnnyC for writing the awesome firmware (star momentary 1.6) that I used in this light.
EDIT2: If a beginner wants to repurpose Nanjg driver like me, please do not use solid core wires as they are not flexible, you may have a hard time pushing the driver down.
Sorry, my mistake on the XP-L2 statementā¦ the emitters I got in mine were XP-L V6 2C/2D. Nice tint, nice output. Yes, the 3000 lumens out of the box was correct.
Another good news guys! I tried to convince Sofirn to sell switch tailcaps separately. So if you want you can lockout the C8F with it. I hope they will have it in the store soon.
Confused, sorry-- I guess you have a FEW of these C8Fs ;) But your batch of XP-L2s (that you mention earlier) from Arrow... I ordered the same (I think), anyway wondering if I'm remembering right where you DO have BOTH an XPL Hi and XL-L2 FC8, right? If so was wondering if you had an opinion to share with regard to the differences between the two?
Also, didn't you also try the SST-40? (or what that another light- you write about so many!)
