Pulling back from the stats & the charts, are you folks seeing these “swings” in thermal ramping with your naked eyes? I am having a hard time making out an appreciable swing up/down as captured in these charts.
I also have a hard time seeing lumen changes with my eyes. I suppose it’s a blessing for me. I’m really enjoying this light. My wife pretty much claimed it as hers and she is quick to grab it when walking the dogs. I get to use it mainly when investigating bumps in the night (dang raccoons!).
If you want continuous (higher) output, get the last version of the SP33 (V2, also know as the “new version” which it is not- but what they call it on their site). That version holds a nice continuous output while the new version is said to throttle back (and forth) not keeping up quite as well on the “continuous” output side of things. It is ALSO closer to $20 without a battery (when bought right). If Sofirn sells it WITH a battery, then I think it may be a PBL re-wrap (great battery).
Or if you want something kinda in between- check out the IF25a. Easily as bright as the SP-33 BUT with more heat (but kinda nice in winter- hand warmer effect and it’s got a nice WIDE beam— at least as wide as the SP-33) and it runs on higher capacity (4500-5000mAh) 21700 batteries fine and goes longer between charges.
My wife loves her little SC31 Pro, but she charges it every other walk (25 min. or so x 2) where as she can take the SP33 (V2) or IF25a a few more times before plugging in.
PS. the SD-05 dive light is ALSO a goto for outdoors- simple ring switch (off, low, med. high)- simple AND bright, with an equally nice WIDE beam! AND… it does NOT step down like most do after a minute or two. Good price for like $22 from Sofirnlight.com. One of my favorite outdoor lights lately
liquidretro, nice review. As a strictly muggle flashlight owner I find the V3 useful. It is my only 26650 and I like that it goes for a month the way I use it before needing to recharge. The thermal regulation issues don’t bother me much since I rarely get to that point in daily use. The thing really gets out there on the farm and I can see any animal, authorized or not. 4000k would be nice, though it wouldn’t reach as far. A good option is being able to throw in an 18650 if needed. I got the V3 for a nice price with the discount, 30 something. It’s a good flashlight for the money. I have a number of their other flashlights and use them all from time to time. Good company.
Thanks for the info on the V2, I shall read the reviews on that and the others that you’ve mentioned. I had hoped that there might be some more dev on the V3 but only time will tell.
The SC31 Pro is a great light, especially when I was using an incan Maglite before… I also had the 31B but passed that on to my good lady when I received the pro.
Per my test, the SP33 “v2” now (uses XHP50.2 3-volt LED) doesn’t have that “continuous” output.
Only the earlier batch SP33v2 (uses XHP50.2 6-volt LED) has the constant regulation, and that earlier batch doesn’t seem available (unless older stock).
Oops! I missed that bit of info! :person_facepalming:
I indeed have the old V2 version (and the older XML original version before that!). And I do also have the V3 (several) as well. Good lights in any version really.
But given a choice between the NEW V2 and the SD-05 (dive light) I’d get the SD-05. It’s not too blue in the standard 6k (or so) config, but I like the 5k range and so I’m ALSO waiting on 5k versions of BOTH an SP33 V3 and SD-05 (which went out-of-stock about 3 months back).
I have the 6volt SP33 V2 with the regulated driver. It does not get hot on high and mine does not step down. Only problem is mine loses turbo about at 3.9 volts, not 3.7 v. The SD05 3 volt model is very nice. The combo flood/throw is about perfect. It does step down when it gets hot but medium is sustainable and is about 900 lumens.
The older SD05 (“2550 lumens” manufacturer spec) also uses XHP50.2 6 volt LED (by my guess), since it has the same max tailcap current of around 6 Amps (same as earlier SP33v2).
The newer SD05 which now has “3000” lumens manufacturer spec), now uses XHP50.2 3 volt LED (per my guess), the max tailcap current is now higher — similar to the new SP33v2, around 8-9 Amps or maybe up to 10 Amps max, depending on the battery.
Another thing I noticed:
older SD05 and also the earlier SP33v2, do not have PWM on all modes (lower brightness)
the newer SD05 and the new SP33v2, will use “fast” PWM on lower brightness levels (may not be visible though unless specifically checking for it like I do by shining the flashlight through fan blades)
Mine arrived this afternoon and I’m certainly pleased with the way it looks… It’s on charge at the moment and I’m looking forward to walking the dog when it gets dark.
