Man, I really want that king now.... am I wrong or does it look like it throws quite a bit better than the DRY, and with the same or better total output?
And yeah, I like that picture too.
My monitor is 1440x900 - but whatever is easiest for you - I'll just fill the background w/ black - THANKS!
You can download the high res version here (1920x1200pix).
I don't usually upload any high res photos to net, but BLF is an exception.. ;)
Side by side photos of DRY & King, as promised:
Skyray is about 1mm wider when measured from bezel and the body is about 6mm wider.
Sorry, I didn't take beamshot with low. :( I will next time.. And it is bright, at least in my opinion.
You are right. At least that's the situation with my samples.
Ceiling bounce gives the same result than my Xeno E03 NW on Med with 14500 => About 300 lumens, maybe a bit less?
Trigger mechanism is good and the UI is user friendly. The more I use it, the more I like it.
And no, I don't seem to have the switch problem FX-32 mentioned. I tried repeating Hi-Lo-Off more than 30 times and didn't see any sign of that problem.
Great photos!
thanks for the exception ;)
thankyou very much for the size photos! Hard to believe its that much shorter and fits one more battery than the dry!
