Can anyone please clarify for me, for the SP10S, in which mode does it turn on? The OP says it comes on in low and you have to cycle through all modes to get to eco, or moonlight. However the product description on Sofirn says that it turns on in eco, like the SP10b used to. Is it possible they updated the driver since this thread was started due to the criticism? I’d like to get a driver to replace the one I mucked up in an older SP10b but I will wait for new developments if does not turn on in eco. I’ve looked for other reviews but they are all old or conflicting about this.
Thanks for the comment. So if you are using 14500, does it come on in eco? We used it as a bathroom light on a trip to Iceland and eco was perfect for that. If it comes on in eco using 14500 it is just like SP10b. I probably will wait anyway, to see if the Anduril driver ever comes out.
SP10S lowest level seems to be about 1 lumen (or maybe just a bit lower), I find it acceptable as a “Moon” mode.
The SP10B’s lowest level is very low (likely less than 0.5 lumen), and is (mostly) useless though.
However, one thing I find nicer on the SP10B is the shortcuts.
On the SP10S, there is no shortcut to Lowest mode (Hold from Off does not do anything - does not turn on the flashlight). Single-click (with 14500) goes to Mode Memory; and to 2nd level (with AA battery). No direct-Moon whether AA or Li-Ion.
On the SP10B, it has a shortcut to Lowest level and to Mode memory, although the UI seems to be counter-intuitive now that there are several flashlights that use “Hold from Off” to go to Moon mode (eg. Narsil, Anduril, and some other lights).
On the SP10B, “Hold from Off” goes to Mode Memory (Last used level), whereas a single click goes to Moon (wish they had included this short for the SP10S, but swap them, so that single click goes to Mode Memory, while “Hold from Off” goes to Moon level).
About all the moon mode is good for on the B is to drain the battery when you put it away without knowing it is on. Really hard to use for work when you have to constantly check it before pocketing it.
I will comment for the first time.
When I started using the SP10S, I also noticed that the memory behavior sometimes went wrong.
This seems to be due to the driver board not correctly identifying the battery type, which is more likely to occur when swapping from 14500 to AA and vice versa.
In other words, the memory function appears when switching from 14500 to eneloop, or there is no memory function when switching from eneloop to 14500.
To prevent this, it seems that pressing the button for more than 1 second when the battery is not in it will accurately recognize the battery type the next time the battery is connected.
As for the UI, I’m very dissatisfied with the fact that the direct ECO access that was on SP10B has disappeared on SP10S.
Also, when the battery is exhausted and the LVP operates, the light turns off once in eneloop, and when the button is pressed, it activates as a LOW one-mode light. ECO cannot be used. I wish I had two modes, ECO and LOW.
I’m a DIY enthusiast, but there are two types of high-performance AA / 14500 drivers currently available at low prices, the SP10S and CONVOY T2 (4 mode). I need to know more about these behaviors.
