I had done a lot of research on “button top” vs “raised top” and even got in touch with HKJ to see what he recommended.His answer was clear and unequivocal.It appears that some high-end flashlights cannot be used with the broader “raised top” and the “button tops” are not only compact but they do make good contact with any good spring as long as there is the normal amount of pressure.
So whats the point of having the protection as high as 11,5A?
Most cells can do 2C right? (??) So 6,8A should be ok, and pushing the limits a bit higher would probably not be that bad (despite decreasing battery life)? Or am I off now? (I know 1C is what is really recommended).
I know mountain electronics have protected PF (Orbtronic), but protection kicks in around 6,5A...
My intl-outdoor 2900mAh (PD) Protected cells probably have around 11,5A trip current, but those cells are not available anymore. (And they were pretty expensive). I am not aware of any of the newer PF cells with protection at 8A++.
