So, Lexel, what do you think is the approximate percentage that part is of the total price? Surely, the reflector part is a significant portion. Do you think the ‘middle’ head section could go for <50% of the total light? Not that Lumintop would do it anyway, probably.
Okay, rookie question here. Regarding the mcpcb, why can’t we just replace the 35 HI emitter with a 70.2 on the same stock board? Would this work with either TA’s driver or with the stock driver? As VoB explained in his video, the 6v vs 12v distinction is irrelevant.
As a side note, there is a corona and some major bleed on th of light that makes it hard to see what you are shining upon. Using Matt's video of the Xhp-70 modded light. Is there any way to find the sweet spot of the reflector to clean up the beam? Maybe it's in material but its really hard to tell from Matt's video. After all, the GT was to be a thrower not a flood right? The foreground of the Xhp 70 actually detracts from the distant image. One's pupil is bound to close up as a result effecting the contrast level.
The part circled is probably most of the cost of the BLF GT. The metal tube,
the tail cap, and the battery cages probably cost less than $20 all combined.
So I would be ok with a discount if we only buy the head vs the entire package. I don’t really have a need for another midtube and two more battery cages every time I want to buy an upgrade for the GT.
They could charge full price for someone who wants the entire thing, and give a discount for people who only want to buy the head. 95% was just a ballpark, I don’t know the exact figures.
For one thing, the numbers in XHP70 and XHP35 refer to the dimensions of the emitter packages, in 1/10th of a mm. So, a XHP70 is twice as long on a side as an XHP35. It won’t fit.
Here is a quick picture that I found of the emitter pad sizes.
I would still like to see a sliced dome xhp50.2 running at a regulated 6 amp 12 volt in the GT. This is pretty much the same die size as the CFT-90. I’m curious as to how similar they are.
They were refering to the just the lower part of the head, what we call the light engine. Bottom right in this pic. It’s a much smaller package, lighter and easier to ship.
Sorry, I was going by memory. Yes, 6A 12v is too high. It seems to peak about 5A 12v with 5000 lumen. If we get a similar loss in lumens by slicing the dome as we did with the 70.2, we can calculate a 13% loss of output.
So 5A 12v maybe gives 4300 lumen. That’s about double the xhp35-HI, right? I’m just curious to compare it to the CFT-90 since the die sizes are the same*.
So do you mean they may actually make a separate light engine running this setup available?
How many would people would need to be interested?
I know I would be interested. Have the opinion of swapping back and fourth
