In answer to your edited question. RMM uses the zener to deal with the voltage spike issue that happens with high currents in the FET. The zener would bleed the voltage spike off keeping the MCU from seeing it.
Since these drivers are using DEL’s updated schematic this is not an issue for these drivers in theory. The new parts fix the voltage spike from happening.
So you can use the zener if desired but they should not be needed.
I put them on the driver simply because I wanted a driver that could do everything, including multi-cell setups.
Plus the zeners bump up parasitic drain on e-switch lights. I've been pulling them off, using the 4.7 ohm resistor instead, before the diode - has to be jury rigged in, however.
As Tom said, the zener is not the best idea for an E-switch light unless you can lock it out when not in use / have dual switches. It will slowly drain the battery even with the light off unless you lock out the light somehow.
As an example I have another driver using the classic parts list and I tried using it in a triple 219C. Well it works fine until it tries to engage the FET, then it goes wonky and shuts down. Seeing as these drivers have worked fine with lower current builds I am pretty sure this is due to the voltage spike although I didn’t put it on the scope to verify.
This is part of the reason I wanted to build these drivers, this way I can have it all in a single design that can be used with basically any light I desire.
Be sure to post if you order the boards and how they work out for you! I want to catch any possible issues early on, plus I am curious what people think of them once they start being used.
Well assuming that your solder mask is aligned properly, the only one I noticed was the via that was right below one of the back side 7135 grounds. Just make sure you don’t use too much solder paste on that ground and you should be fine. The latest boards have the via moved to eliminate this possible issue.
Obviously look the boards over carefully to make sure the mask is properly aligned as well.
Other then that just be careful to not use too much solder paste on anything, it doesn’t take much to get a good connection. With tightly packed boards such as this, less is more when it comes to solder. It is a lot easier to add more then to remove it.
Not sure if it makes much difference, but I always believed the 7135's grnd connection is both for an electrical and thermal connection, so the grnd pads should be as big as can be. Out traditional stacking didn't help heat flow much, but I made sure I always did the front center pin and back tab when stacking. DEL believes the thermal use is important as well, and had PD68 expand the 7135 grnd pads. Your board, specially the 17's, are jam packed, so I dunno if you got room to make them much bigger. Just fyi...
Yeah, the ground pads are indeed for heat sinking as well.
The pads fully cover all the pin that sticks out past the body as it is, the issue is extending it to the “center” of the 7135 would cut the current trace. I could possibly extended it down ever so slightly but I highly doubt it would make any difference as it would be a minute change.
The big copper trace under the 7135’s also acts as a heat sink as well, even if not directly soldered to it.
My thinking was that the 7135’s in drivers like the 105C, SRK or even the Q8 with basically no heat sinking at all work properly, not to mention all the stacked 7135’s out there. Even with running 2S they seem to work fine.
So I figure with all the copper running under and around them combined with the ground being directly connected to the pill via solder/retaining ring ideally, I think it should be ok.
I just built a convoy L2 and let it run on the 7135’s for a few mins and it had no issues.
If people really think it will be an issue I could try to redesign it to have a full ground pad but it will have basically no spring pad and it will be UGLY when it comes to trace setup and have basically no trace width for the current trace.
I don't have the direct experiences with the heat issues of 7135's, but from the practical side, I thought O-L has proven it, and from the theory side, DEL feels strongly about it, and there was lots in-between with discussions on it over the years here.
O-L actually built at least one modded light up when using extra banks of 7135's, mounting them on separate PCB's with added heat sinks, to avoid the stacking heat problems. I don't think he would have done that without direct knowledge, and I seem to recall it solved his problems he had with stacking for the mod originally. I recall the photo in my head, but can't remember the mod thread. I do know the one specific light the mod thread was on, Daylighter ended up with the flashlight.
I thought the 7135's don't fail, just result in loss's of amps when hot. There's some threads on it if you search for 7136 heat, etc., but probably more you can't find so easy in a search.
Yeah, I did a lot of reading on those issues before designing these. I came to the conclusion that for a 1s setup as long as the driver is connected to the flashlight well and the ground is on the outside of the driver, that things should work well.
The 105C being used for years and working fine with basically zero heat sinking at all was what kind settled it for me. Even with running 2s many threads said that it worked without an issue.
These have better heat sinking then a 105, so I see no reason it would not work as well as they do?
Apparently they have built-in throttling when too hot, but I thought the consensus was if you have direct ground ring contact, you’re fine. You only have problems with stacked chips amd floating boards
For the 7135s you should be fine if you are on the ring.
On the Q8 driver it sits in the middle. It is also a kind of a worst case 1S application since 4 cells with one 7135 does not droop much and in addition the Vf is low with 4 emitters sharing the current.
DEL - I thought the pad sizes were somewhat important? Also the middle pin of the 3 not connected?
Ohh - posted in the L6 thread. If the 30mm would have LDO support, I'd definitely be ordering and using them for L6's. In fact I'd buy another L6 just because of the driver w/LDO . I'm really only interested in LDO, not zener. You could use a zener of course, then have the extra drain if you don't turn it off on the tail. I got a few Y3's around, and some other dual switch lights - need to do some testing w/Narsil dual switch...
That’s what I thought when I did my last L6 driver mod: FET+1 and 105C as slave. It worked well and then a I did a runtime check with 9x 7135 only. Was very surprised, it ran so long as if my Keeppower 5200 had a capacity of far more then 6000 mAh (like the Trustfires ). I did some measurements and found out the 7135s reduced output after 10 seconds and pulled 30% less current due to the heat. Wasn’t directly visible though.
