The BLF GT70 "Giggle Monster" is here! 7,500lumens, 1,500m throw! Group buy Closed!
2 x battery carriers and lenses.
Nice work guys. :+1:
Filled the form for a neutral mod kit.
Or the lower head light engine if turning out to be that way.
I have been using the short tubes on my GTs. Those of us with short and long tubes could make use of spare parts if we were able to buy:
1.Complete head
2.Tailcap
3. Battery Carrier
I would imagine quite a few of us have GTs already with both battery configurations and would like to have a lower cost alternative to make 2 complete lights.
Keep in mind that Lumintop has not built this light yet, so there’s not even a prototype to get measurements from (AFAIK). There are only the several modified GT’s that TA has built and measured.
I have asked TA what specs we should post for the dome-on led. When he wakes up, this info will be updated along with a driver amp draw. It currently says 2.5A @ 12v, but that is a carry over from the original GT spec. The new version should be closer to 7A to 9A range. Plus it might vary based on whether one or two carriers are used.
Before he sliced the dome off he was getting around 1100m to 1200m throw iirc. I can’t remember if that was with all springs bypassed or not.
Dont worry, these specs will be updated soon.
Form filled out and submitted.
Here is what TA said about it on another thread.
I’d like to go in for two:
one neutral white
one cool white (could not indicate separate color temp on form)
Also 4x extra carriers
No lenses, conversion kits, or reflectors.
Thanks!
A complete head could very well cost 90% of the total lights price. So would you really save any money?
I don’t know the exact number but the cost of the head is by far the most expensive part.
I am in for 1
NW
Submitted
1 x BLF GT70, CW
Filled out the form for 1 conversion kit, thanks TA.
Filled the form, in for:
1x GT70 NW
1x conversion kit NW
1x spare lens
8x 30Q cells
Sadly the savings of leaving out the battery tube and carriers would be minimal, maybe $30, the bulk of the cost is the head so it doesn’t make a lot of sense to sell it separately.
Remember that both the head and the reflector start out as big solid hunks of aluminum, that is a lot of cost and machine work.
The issue here is that many people have a big problem opening up the GT, so it could lead to more issues then it fixes. Otherwise this is what would of been offered instead of the kit.
Thanks, I will update that in a little bit
Impressive way you are setting this up TA!! Very impressive compared to previous Group Buys…. :+1:
Google Form submitted for:
  • 1 x BLF GT70
  • 2 x Conversion Kits
  • 2 x Battery Carriers
  • Interested in lens, reflector, & batteries
Also if Neutral White is between 5000K - 5500K that will be good. Otherwise CW for me.
From Google form
Neutral white - 4000k - 5500k
Cool White - 5700k and above
Warm White - 3700k and below
That was a mis-understanding. The specs in the OP are in fact approximately what the final numbers should be as delivered from lumintop with the dome on.
In fact I am actually under-rating them since we do not know the exact LED model yet. If for some reason they can not get P2 bin emitters, then the numbers might have to be adjusted. We will know more in a week or 2 when they find some LED options.
I tested a P2 bin 5700k light just yesterday and the numbers posted are a good bit under-rated from what I got to give some wiggle room.
It is a TA V2 driver that replaces the 7135’s with a resistor bank. 7135’s die at 12V and do not like 6V so I have to find another option and after a lot of testing and prototyping this has proved to work very well.
The lumens and throw ratings at this point are only an educated estimate as we have not found the production LED yet but based on my own testing and VOB’s among others, these numbers are well within reason. Worst case we can go with some P2 5700k emitters hit them.
The only real trick is finding a 5000k P2 bin, these are harder to find and I have not tested them yet obviously.
If people would prefer I can under-rate the ratings even more for the time being or just remove them entirely until we find the production LED and get some hard numbers. Although I am pretty sure they will be within ~10% of the numbers I posted if they are P2 binned.
I filled the form for:
1 flashlight
neutral white
with batteries
extra glass plate
no other extras
Signed for 2 conversion kits. Is there a way to see the sign up results in google? IE total number of people etc?
For the Cool LEDs. My 2 cents is to absolutely go as cool as possible. Especially since a de-dome will lower the temp. I cant even tell you how many people have been blowing up my email because they want the laser like effect generated by the cool white.
Fasttech has P2 6000k emitters. The exact emitter I used for my build.
https://www.fasttech.com/products/0/10036285/7908500-cree-xhp70-2-p2-1a-4292lm-6000k-led-emitter
