The GT70 is definitely more bang for your buck in terms of price. It should have a larger hot spot than the other light.
The GTvnV2 seems like youād need to use binoculars to use itās full range. It has a bit smaller hot spot than GT70.
Personally Iād get the GT70 to try it out since itās so much cheaper. If you try it out and still think you need more distance and arenāt finicky about the exact color of the beam, you can slice the dome off and gain another 400 to 500 meters.
If thatās still not enough distance for you, Iām sure you could sell the GT70 and then get the GTvnV2.
If I look at the distance the sliced dome version GT70 has, which is about 2000 meters, your paying 3 times the price for 40% more distance with the GTvnX2.
Iām holding out for the NW and will probably get any extra parts offered. I know the majority of people here want the NW. Just want to make sure we will all get one even if more people than planned order the CW. Or people order more CW than they committed too. Cheers.
Yep, that was what happened. Banggood made a mistake with the listing at first. They have raised the price to $275 now but lumintop said it should not be that low (this is pretty common for banggood to list items too cheap and has hurt a lot of manufactures over the years). We will see what the final price ends up being, I was told $300-325 was the retail price they were planning on.
The shipping will indeed be much cheaper from Banggood as they get subsidized shipping from the China government and lumintop does not.
Also, lumintop is preparing the neutral white LED order.
Getting them to offer both 4000k and 5000k is not looking likely, they are worried about getting them mixed up and people being upset, which I can understand.
So that leaves them with a tough choice between a 5000k N4 bin LED or a 4000k P2 bin LED that is half the price.
Brighter and lower cost, I am gonna say that the 4000k is pulling ahead if they only offer 1 option for better or worse.
Something like that depending on what the retail price ends up being once the banggood listing goes live. Lumintop was not even aware they had listed the GT70 when I contacted them.
Also keep in mind that pre-orders on banggood are generally at a discounted rate as well.
